Thread: Brake Job First Timer - Advice Needed
Results 1 to 2 of 2
  1. #1 Brake Job First Timer - Advice Needed
    Jul 2008
    Roseville, MI
    I have a '97 GT and my rear brakes are pretty bad. I had planned on replacing the rotors and pads. What should I look for on the calipers if they need to be replaced/serviced?
    I see the caliper rebuild kits ($6) is this always a good idea to do when doing brake work? What does it entail?
    I'm looking at the parts lists and need to make decisions. I don't feel that I need to upgrade anything. I don't race my car, I just go from home to work and back. I was going to pick up the Raybaestos Rotors. What about the pads? Ceramic? Organic? Semi-Metalic? What should I do? I've heard the pads need to be properly matched to the rotors. I don't want a ton of dust and no noise. Advice is appreciated.
    How about tips for the overall job?
    I imagine the job goes something like this:
    1. Jack up car, put on jack stands.
    2. Remove wheels.
    3. Remove caliper.
    4. Remove rotor.
    5. Clean existing surfaces and the new rotor
    6. Install rotor
    7. Clamp caliper to install new clips/pad
    8. lube moving parts/rubbing surfaces
    9. Reinstall caliper
    10. Put wheel on
    11. Lower car and go for a spin
    Do I have to worry about the master cylinder over-flowing? What do I do about that?
    --Thanks--
  2. #2 Re: Brake Job First Timer - Advice Needed
    GTP Level Member David99GTP's Avatar
    Florida
    Its pretty easy to do. GM breaks are some of the easiest to work on. Best thing you can buy for your car is a repair manual from autozone. Runs about 15 bucks and gives you a lot of good tips. Oh and get a can of PB blaster, soak down all your bolts the night before. It will save your knuckles lol
    1999 GTP
    2002 Chevy 2500HD lifted on 36" Swampers
    http://www.cardomain.com/ride/2619487
  1. CarFax Needed
    By JJ91284 in forum Off Topic Discussion
    Last Post: 07-02-2008, 11:42 AM
  2. input needed
    By UWISHU1 in forum General Tech Discussion
    Last Post: 06-29-2008, 10:46 AM
  3. When is the Non-HD to HD Trans Upgrade Needed
    By VinnieGTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-16-2008, 03:53 PM
  4. Transmission help needed
    By smokinum in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-14-2008, 10:23 AM
  5. Need Advice on 97 GTP
    By GreenNirvana101 in forum Off Topic Discussion
    Last Post: 03-02-2008, 12:46 AM
