You might be able to.. although it is much easier w/o pressure on the bar.
you may be able to jack up one side at a time, remove the wheel and get to the caps for the bushings too, i just put a new sway in and its easier to get to the cap bolts if you drop the cradle some, or gear wrenches will have to do, a socket wont fit so well on the d/s rear cap, its in a real tight space.
