Thread: anyone want an abs removal how to thread?
Results 1 to 15 of 15
  1. #1 anyone want an abs removal how to thread?
    SexyStudmuffin copperpacecar's Avatar
    Feb 2010
    somewhere cold
    i finally made my abs go away!!! i was thinking about adding a how to but i dont really wanna do the work writing one up if no one is interested...
  2. #2 Re: anyone want an abs removal how to thread?
    Feb 2008
    Yes Please! Does your magnasteer still function correctly? I only ask because mine doesn't if I pull the ABS fuse.
  3. #3 Re: anyone want an abs removal how to thread?
    Feb 2010
    somewhere cold
    whats a magnasteer?
  4. #4 Re: anyone want an abs removal how to thread?
    magnasteer is pretty much what it sounds like. it amplifies your turning.
  5. #5 Re: anyone want an abs removal how to thread?
    GTP Level Member SnowDrift's Avatar
    Apr 2009
    Central Ohio map dot.
    Quote Originally Posted by copperpacecar View Post
    whats a magnasteer?
    Rack glides over opposing lines of force on magnets, if I understand it correctly
    What would be the purpose for making the ABS go away?
  6. #6 Re: anyone want an abs removal how to thread?
    St. Louis
    1. Magnasteer is an electronic device added to conventional power rack and pinion steering to vary the amount of effort required to steer the car, dependent on vehicle speed. At low speeds, steering effort is lower for ease in parking. As speed increases steering effort is increased for greater road feel. Additionally, on some models evasive steering maneuvers also affect steering effort.
    2. The purpose of making the ABS go away I presume would be if you had a failing ABS pump/system and did not want to repair/replace it. Other than that, not sure.
    Be warned though- If you have an accident your ins. co. may deny the claim since you removed a factory installed safety item from the vehicle. You may be liable for damages to both your own vehicle and others involved, and any resulting injuries to either party.
    When your brakes are locked up you will travel in a straight line and not be able to steer around objects. ABS give you the ability to steer your vehicle - while appling max braking force. It is impossible for any human to pump the brakes anywhere near as fast as what the computer can do.
  7. #7 Re: anyone want an abs removal how to thread?
    Feb 2008
    Like in my case, where the ABS controller is absolutely retarded and does nothing except prevent the car from slowing altogether.
  8. #8 Re: anyone want an abs removal how to thread?
    Texas
    Yes turbo guys would be all over this since some have to delete there's to get the upper dp to fit. I say DO IT!!!!
    85 Corvette
    01 TA
    03 Z06
  9. #9 Re: anyone want an abs removal how to thread?
    GTP Level Member KwazrollinZ28GTP's Avatar
    FLINT/michigan
    PLEASE PLEASE show us
    1997 GTP 2DR RaceKAR
    1994 Z28 intake, small cam, exhaust leak
    2000 silverado 5.3l Z71 3.73gear posi, 3.5" lift 33" tires DIABLO Tune
  10. #10 Re: anyone want an abs removal how to thread?
    Feb 2010
    somewhere cold
    well i dont have a magnasteer thingy so i didnt have a single problem..as for the reasoning behind removing the abs, well, first i hate abs and dont drive my car during the winter anyways and rarely i the rain. yes i could have just cut a sensor wire or unhooked the wheel bearing sensor, and i did two years ago, but i hated the look of the abs pump so i wanted it gone. yes it also removed about 15 pounds although i could care less about weight although someone may. also i plan on painting my engine bay when i repaint this fall (as you can see its much needed from my pic) so that ugly ass block of abs modular is a lot easier to paint around when its not there. besides im unique now although thats never been a problem before. as for the accident senario...thanks for the thought as i hadnt considered that and i will call my insurance company tomorrow to get specifics so i can remain covered
  11. #11 Re: anyone want an abs removal how to thread?
    Texas
    We need write up please.
    85 Corvette
    01 TA
    03 Z06
  12. #12 Re: anyone want an abs removal how to thread?
    GT Level Member 40th GP's Avatar
    Utah
    What is the status? What did you find out about from the insurance company? Would this be any different if it were intentionally removed vs. the many people on the road with the ABS not working (like mine)?
  13. #13 Re: anyone want an abs removal how to thread?
    GTX Level Member cliffdawg's Avatar
    Midvale, Utah, United States
    very interested in this lookin into deleting mine beings my abs light and parking brake light has been on for 3000 miles haha
    SMGPFC #77
    94 Firehawk - #108 of 500
    97 GTP Coupe - Rebuilt Trans, F1 Hood, Front Air Dam, and Gen 5 Blower Swap than done with modding
  14. #14 Re: anyone want an abs removal how to thread?
    SE Level Member BlackGT1's Avatar
    Sep 2011
    Fort Worth, Texas
    Haha my ABS is on too, but I know what mine is, the right front speed sensor is messed up, the wire was cut. But would that make my magnasteer go away? I don't think I've even payed attention to if I have it, I generally only go fast in straight lines.
  15. #15 Re: anyone want an abs removal how to thread?
    I'd just like to know which Master Cylinder you used...that's all I care about
    But if you do want to do a write-up...I'd be more than happy to sticky it in the How To Section.
  1. Transmission Removal help
    By jagman454 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-15-2010, 11:42 PM
  2. Rear Hub Removal
    By trenaro in forum Brakes/Suspension/Chassis
    Last Post: 07-26-2009, 06:18 PM
  3. 98 gtp dash removal
    By mscott9549 in forum Audio, Security & Visual Electronics
    Last Post: 02-05-2009, 08:43 AM
  4. engine removal
    By stanwich in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-11-2008, 11:23 PM
  5. Dash Removal?
    By Bogers99GTP in forum General Tech Discussion
    Last Post: 10-21-2008, 05:58 PM
