Thread: Rear Strut replacement 04+?
Results 1 to 7 of 7
  1. #1 Rear Strut replacement 04+?
    Michigan
    I have an 07 gt and im hearing the clunking noise when i go over bumps so i feel like its a safe bet that the strut could be shot. what is the best way to go about trouble shooting this and is there a writeup on removal and installation?
  2. #2 Re: Rear Strut replacement 04+?
    Omaha, NE
    With the car in park, just sitting push down on the trunk you should be able to find where the noise is coming from.
    Removal: Take out your back seats, take off the wheel, take off the 2 bolts at the bottom of the strut, take out the 3 bolts in the trunk, take the top mount off, remove the spring.
    Install is the opposite.
  3. #3 Re: Rear Strut replacement 04+?
    yes theres a write up but its for a 97-03 gp im sure its the same thing tho
    Edit= nevermind
    SMGPFC Member #10
  4. #4 Re: Rear Strut replacement 04+?
    Omaha, NE
    The service manual on GPONA has a pretty well detailed write up.
  5. #5 Re: Rear Strut replacement 04+?
    Michigan
    do you have a link for that? im confident enough that i could do it i just want it to go as smoothly as possible because i tend to get impatient when it comes to working in the garage
  6. #6 Re: Rear Strut replacement 04+?
    Omaha, NE
    The service manual never links right. Go to GPONA.com, and register if you havent, when you log in it will say service manual at the top of the page, put in your year, make, model and go to the service manual. It should be the first link on the page after you put in your car information. Then type strut in the search and you should find what you need.
  7. #7 Re: Rear Strut replacement 04+?
    Michigan
    found it. thank you
  1. Rear strut question
    By Dude in forum Brakes/Suspension/Chassis
    Last Post: 08-19-2011, 11:11 AM
  2. 2006 GP Strut Replacement ?
    By DC1263 in forum Brakes/Suspension/Chassis
    Last Post: 04-22-2011, 06:30 PM
  3. Strut replacement
    By chumley in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2010, 08:59 PM
  4. 2007 Grand Prix Strut Replacement
    By uibob7 in forum Brakes/Suspension/Chassis
    Last Post: 03-15-2010, 07:30 PM
  5. Need help, strut replacement
    By rodie1200 in forum Brakes/Suspension/Chassis
    Last Post: 07-19-2009, 08:36 PM
