Thread: Traction control light and abs light on
Results 1 to 6 of 6
  1. #1 Traction control light and abs light on
    Aug 2011
    wv
    my steering wheel shook very bad, especially when going down a hill. also the the brakes get a pulsating feeling in the peddle. no my service traction control light and service abs light is on. so they said i needed all 4 rotors replaced, a full wheel alignment and brake pads. i had all this done now they say i need speed sensors??? this car is a 2007 grand prix and only has 43,000 miles. ive never had a car require this much repair in this period of time. why does this happen? and all 4 rotors at the same time? and what are speed sensors? it cost me 665.00 dollars so far and am looking at another 400 for speed sensors and installation. i dont really have any idea about this and dont want to get taken. thank you to anyone that can help answer my questions.
  2. #2 Re: Traction control light and abs light on
    London Ont, Canada
    rotors - probably not.
    Wheel hub - damn skippy.
  3. #3 Re: Traction control light and abs light on
    MA
    Most of the Time the abs and TCS lights mean a bad wheel hub. Some have found it's sometimes as simple as a crimped wire coming off the wheel hub.
    Why they're thinking wheel speed sensor? I haven't a clue
    SMGPFC Member #9
  4. #4 Re: Traction control light and abs light on
    SE Level Member postalc38's Avatar
    Brant, Michigan, United States
    Because the wheel speed sensor is included in the hub, the sensor stops sending a reading for the ABS, which sets the ABS and Traction lights on......
    We need a statement at the top end of this section that says search before you type any thread with the words ABS or Traction lights...
    It was probably time for new pads anyway, however i'm sure your rotors probably could of just been turned (unless you had other braking issues).
    2000 GP - 157K (DD/Crash damaged project)
    1995 Olds Aurora L47 - 222K
  5. #5 Re: Traction control light and abs light on
    Sep 2011
    NEW YORK
    i had the same problem and it was my hub but i have also had those lights come on when my brakes and rotors were shot. If you have a gxp with the drilled and slotted rotors i sugguest changing them yourself and it may sound crazy but napa autoparts has great rotors that are drilled and slotted and they have lasted alot longer than oem parts.
  6. #6 Re: Traction control light and abs light on
    its AWDsome JarenSTi's Avatar
    Hawaii
    Quote Originally Posted by Torri040 View Post
    this car is a grand prix. why does this happen?
    the answer is before the question.
    had the same problem and it was just a broken wire. maybe get an abs code scan?
    2002 WS.6- exhaust, 42k miles
    2005 Subaru WRX
    2002 GT - sold
  1. ABS Traction Off Light
    By Phrozen99 in forum Brakes/Suspension/Chassis
    Last Post: 07-29-2011, 08:17 PM
  2. 05 GT ABS & Traction Control Service Light w/ strange noises
    By zx7r4u2nv in forum General Tech Discussion
    Last Post: 06-02-2011, 09:37 AM
  3. ABS and Traction light
    By nanuke in forum Brakes/Suspension/Chassis
    Last Post: 12-31-2009, 01:19 PM
  4. abs and traction control light on...why???
    By jtheripper211 in forum General Tech Discussion
    Last Post: 09-01-2009, 03:29 PM
  5. ABS / Traction Light
    By bcrosby51 in forum General Tech Discussion
    Last Post: 12-20-2008, 06:10 PM
