Because the wheel speed sensor is included in the hub, the sensor stops sending a reading for the ABS, which sets the ABS and Traction lights on......
We need a statement at the top end of this section that says search before you type any thread with the words ABS or Traction lights...
It was probably time for new pads anyway, however i'm sure your rotors probably could of just been turned (unless you had other braking issues).
