go for it, but i would go for the upper class of the monroe quick struts.
otherwise if you want to spend a little more money, KYB GR2 are a stock replacement and they are an actual good strut. they won't come built, but tearing the old stuff down to swap the springs is easy enough. you should probably replace the upper mounts at the same time as those are probably worn beyond repair as well.
