Thread: Front brake stuck on!
Results 1 to 18 of 18
  1. #1 Front brake stuck on!
    Donating Users Taz Magister's Avatar
    Dec 2010
    Ohio
    Idk what the heck the problem is but the pads are hitting the rotor like non-stop it dosen't really feel like the brakes on it goes in a straight line if I let go of the wheel and you don't hear it grinding but somethings hitting because it just smells like grinding metal and gets really hot.
    Idk where to even start...
  2. #2 Re: Front brake stuck on!
    St. Louis
    Whatever side is generating the heat/smell, pull the caliper off and grease both the bolts w/ some good high-temp grease and reinstall and give that a shot. Sounds like its just sticking. Had my 95 Bonne do that on the drivers side recently.
  3. #3 Re: Front brake stuck on!
    Dec 2010
    Ohio
    I'll try that
  4. #4 Re: Front brake stuck on!
    Dec 2010
    Ohio
    Just going to say somthing most of us know. If BillBoost says it's this part or etc that has failed or is causing your problem just order what ever part he said. or do what ever he said right away because in my experience he's right 100% of the time
  5. #5 Re: Front brake stuck on!
    Dec 2010
    Ohio
    it's the caliper...wth... I guess now I got to upgrade the front brakes because I see no point in buying a new caliper only to replace it with a diffrent one in a few months
  6. #6 Re: Front brake stuck on!
    London Ont, Canada
    Upgrades!
  7. #7 Re: Front brake stuck on!
    I suggested an old brake hose that split and acted as a check valve.
    Your last post makes me think it was the caliper and not the hose. Although I kinda think I might sorta remember giving you a how to check that... ??? Not really sure, I was very very tired.
    F bodies, here you come.
  8. #8 Re: Front brake stuck on!
    Dec 2010
    Ohio
    yea you did and I thought it was the hose so I just droped 20 bucks on an uneeded hose
  9. #9 Re: Front brake stuck on!
    Dec 2010
    Ohio
    so you think its alright to drive 3 miles to work with it the way it is?
  10. #10 Re: Front brake stuck on!
    Dec 2010
    Ohio
    what places sell calipers? like parts stores so I can fix this now I would like to get 04+ but idk
  11. #11 Re: Front brake stuck on!
    napa, autozone. and they will have a core charge, if you dont have the caliper with you at the time you will get charged an extra 80-100 bucks for the core untill you bring it in.
  12. #12 Re: Front brake stuck on!
    Dec 2010
    Ohio
    that and I don't have the same core... ffs
  13. #13 Re: Front brake stuck on!
    why get 04+?
    pretend you have a 2002 monte carlo with a 3.8.
    They wont know they have the wrong brackets on them.
  14. #14 Re: Front brake stuck on!
    GT Level Member MBruneaux's Avatar
    Canterbury, CT
    Try morad or a local bone yard and slap some Steel Braided hoses on there.
    2001 Grand Prix GTP - Daily Driver12" front brake upgrade ('05 Monte), Raptor tune, Open cone, Front and rear strut tower braces, SS brake hoses, BMR trailing arms, ZZP 3" catted downpipe, Dorman front sway bar, GMPP rear sway bar, solid trans and engine mount, flipped dog bones and Borla exhaust.
  15. #15 Re: Front brake stuck on!
    Dec 2010
    Ohio
    I just got a reman for now it cost me close to 40 bucks with tax therw some paint on there and its all good now
  16. #16 Re: Front brake stuck on!
    i got my calipers and rotors from a junkyard for $100 for an 04+
  17. #17 Re: Front brake stuck on!
    Dec 2010
    Ohio
    Yea I need to do it but I'd like to get new rotors and pads when I do it so If I could get some calipers for like 50 and then 50 for pads and 100 for rotors... I'll do it someday after my top swap maybe, but I'm just glad I got it working now
  18. #18 Re: Front brake stuck on!
    SE Level Member SMazza's Avatar
    Jun 2011
    Eastern Pennsylvania
    I just finished rebuilding the left front caliper and replacing the rubber hose, and the inexplicable extra rubber hose on my Intrigue. (Same brakes as GP.) It was hanging up, but not every time I drove it. The wheel would occasionally make some grunting noises and felt a lot hotter than the right front wheel after certain drives.
    I wanted to save money, so instead of paying ~$60 for a rebuilt caliper (best I could find from a known brand), I paid $5 for a rebuild kit and $11 for a new piston. (The sticking caliper was a rebuild, just outside the 2-year warranty.) Also, the rotors and pads were still in good shape, so I didn't want a loaded caliper.
    Rebuilding was fairly easy, once I got the piston out! After taking the caliper off the rotor, I let the brake system pop the piston out ... but it took a lot of pumping. (I stupidly did this after replacing the hose, when I should have done it first. I had to bleed that corner twice - once to build enough pressure to get the piston out, and once after I got the caliper back together.)
    The caliper bore had a thin rust buildup in the area between the piston seal and the dust boot. I don't know if that was enough to cause a sticking caliper, but maybe it could have been. I cleaned it up with a Scotch-brite pad and replaced the seals. I probably could have reused the caliper piston that was in there, but it did show some minor pits, so I used the new one.
    I also installed some speed bleeders on both front calipers ($11), so now I have them on all 4 corners. Saves me from looking for a helper.
    The hoses were a little difficult to remove, but it worked out okay using a 16mm backup wrench on the female fittings. I replaced the mystery hose with a piece of hard line and a union per the writeup I found on this site:
    http://www.grandprixforums.net/5th-b...-6-a-6693.html
    I regreased the caliper slide bolts, of course. The bolts did not show any wear, which was a good sign, but also suggests that simply regreasing them would not have solved the problem. The boots and bushings seemed okay too, so I left them in place.
    Then I bled all 4 brakes, which was pretty quick using the speed bleeders. It was annoying to get to the bleeder screws on the other 3 corners with the wheels installed, but it certainly beats jacking up the car, removing the wheels, and then retorquing them when finished.
    Now, all potential problem spots on that corner are fixed, for only about $40. Well, that, and a wickedly painful sunburn. (Oops.)
  1. can front brake assembly be put on rear??
    By exofis in forum Brakes/Suspension/Chassis
    Last Post: 04-19-2011, 05:09 PM
  2. Parking Brake Thumping/Stuck On?
    By LuckyBambu in forum Brakes/Suspension/Chassis
    Last Post: 09-25-2010, 09:51 AM
  3. back brake piston stuck
    By Lionel in forum Brakes/Suspension/Chassis
    Last Post: 05-29-2010, 06:41 PM
  4. Parking Brake Stuck
    By E90 87SS GTP in forum General Tech Discussion
    Last Post: 10-04-2009, 09:16 PM
