Rotate your tires more often
Rotating the tires won't fix the problem; you'll just get more time to destroy four tires instead of two. If you think the lean is still there, check to make sure the alignment was done to adjust toe (lean). Some places don't check toe, amazing as that seems. If they don't check toe in, go to another place that's competent.
