Thread: ABS/Traction control lights
Results 1 to 5 of 5
  1. #1 ABS/Traction control lights
    SE Level Member thirdrail37's Avatar
    winnipeg mb canada
    So i have new breaks all around, a few days ago my abs kicked in when i was coming up to a stop sign. later my abs and traction control lights came on, and my display screen said to service abs system and service traction control system. WFT? got a 2004 grand prix gt.
    any ideas?
    thanks
  2. #2 Re: ABS/Traction control lights
    SE Level Member postalc38's Avatar
    Brant, Michigan, United States
    Minus catastrophic brake events such as blowing a brake line out, almost all ABS/Traction issues are either related to the wheel hub/bearing assembly and it's wheel speed sensor, or an issue with it's wiring. It can also be the ABS module thing, but that is usually rarer.
    Have someone scan the ABS codes for you. Or search this section of the forum, as there is hundreds of topics relating to this.....
    2000 GP - 157K (DD/Crash damaged project)
    1995 Olds Aurora L47 - 222K
  3. #3 Re: ABS/Traction control lights
    its AWDsome JarenSTi's Avatar
    Hawaii
    ok first of its BRAKES. just sayin
    is it always on or just on sometimes? could be anything so i suggest a scan.
    2002 WS.6- exhaust, 42k miles
    2005 Subaru WRX
    2002 GT - sold
  4. #4 Re: ABS/Traction control lights
    Pennsylvania
    Scan it with a Tech II
  5. #5 Re: ABS/Traction control lights
    Jun 2011
    Chippewa Falls, WI
    My car has done that too, the ABS light will go on, traction control turns off, and brake light comes on. There are many posibilities for it.. Pull your tire and check it for anything abnormal such as disconnected lines or sensors.. I talked to a mechanic who also said that it can sometimes be caused by a drastic blow by for example pot hole that you forgot to avoid. but in this case id have to agree with postal c38.. a scan tool wont always read the correct code for it, it will sometimes just give a general code saying there is something in the abs that is wrong.. essentially getting it scanned is a good idea yes, but it will probably have to be looked at a bit deeper than that for a good diagnosis.. at least in my experience that was the case. As far as the new brakes on the car, that shouldnt have anything to do with it, more of a coincidence. unless a sensor/wire was damaged in the process its very unlikely it has anything to do with new brakes
  1. ABS/Traction and Stabilty Control Lights - Fixed
    By richhurl in forum Brakes/Suspension/Chassis
    Last Post: 06-06-2011, 09:46 AM
  2. Traction control, ABS and Cruise control dont work
    By Adamcc91 in forum Brakes/Suspension/Chassis
    Last Post: 02-04-2011, 05:07 PM
  3. Traction control, stability control , abs brakes warnings
    By warren13 in forum General Tech Discussion
    Last Post: 09-18-2010, 06:26 PM
  4. ABS & Traction Control Lights
    By 98GP*GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-08-2009, 06:40 PM
  5. '99 GT - ABS/Traction Control Lights
    By Sparg93 in forum General Tech Discussion
    Last Post: 01-15-2009, 06:21 PM
