Minus catastrophic brake events such as blowing a brake line out, almost all ABS/Traction issues are either related to the wheel hub/bearing assembly and it's wheel speed sensor, or an issue with it's wiring. It can also be the ABS module thing, but that is usually rarer.
Have someone scan the ABS codes for you. Or search this section of the forum, as there is hundreds of topics relating to this.....
