Thread: How to test ABS with a volt meter?
Results 1 to 2 of 2
  1. #1 How to test ABS with a volt meter?
    SE Level Member mikeplan14's Avatar
    Apr 2011
    Indiana
    I'm having ABS issues, and after much hassle, cannot determine the culprit. I have seen a test that can be done with a voltmeter at each wheel, but I cannot remember where I saw it, or what the procedure was....
  2. #2 Re: How to test ABS with a volt meter?
    check resistance across sensor.
    turn wheel, look for minimum voltage.
    Those numbers are in the GM service manual which can be found on gpona.com
  1. P0102 MAF mass airflow meter code low gas mileage
    By thanospl in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-20-2011, 03:25 PM
  2. auto performance meter
    By MBruneaux in forum General Tech Discussion
    Last Post: 02-08-2010, 06:33 PM
  3. Help ! Headlights and meter lights wont Automatically turn on ?
    By MikeZirpola in forum General Tech Discussion
    Last Post: 11-11-2009, 09:05 PM
