Thread: Brake Warning Light
Results 1 to 20 of 21
  1. #1 Re: Brake Warning Light
    The Boss Iceman6669's Avatar
    Jun 2011
    Quote Originally Posted by Hippo Machine View Post
    Doubt it.
    Dont doubt it Hippo.. It happened to me....Brake light came on.. Checked everything and nothing fixed it, so i decided to do a brake job, and wala.... Fixed it.
  2. #2 Re: Brake Warning Light
    GT Level Member nicks98gtp's Avatar
    michigan
    brake light comes on when fluid level drops below the sensor plugged into the master cylinder reservoir. As the pads wear it takes more to push them out against the rotor. If the pads/rotors are worn to such an extent that they are pushing out that far to contact one another it will set the light off. Its normally a closed switch so when the level drops it drops the float and opens the connection to the plug resulting in the BRAKE light turning on. You should be able to remove the plug and jump the two terminals with a paper clip and it should shut off if its functioning correctly, and the lgith should come back on when the clip is removed. Repalce pads/rotors, refill fluid and you should be set to go. Otherwise it could be the sensor not registering the EBRAKE being disengaged, a lot more rare occurence but also a possibility. id start with the fluid level first
    98 Gtp, ported s/c, fully rebuilt motor .20 oversized pistons, rebuilt trans, zzp pcm,more mods to come
  1. Check gauges, and low gas warning light problem
    By STE2400 in forum General Tech Discussion
    Last Post: 02-19-2011, 09:09 AM
  2. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  3. Water in LR brake light housing/ABS light
    By andante147 in forum General Tech Discussion
    Last Post: 05-31-2010, 08:01 PM
  4. warning light
    By theextreem in forum Shops and Community Heroes
    Last Post: 03-06-2010, 02:01 PM
  5. ABS warning light
    By BankRupt in forum General Tech Discussion
    Last Post: 07-15-2008, 12:48 AM
