Thread: Check gauges, and low gas warning light problem
Results 1 to 9 of 9
STE2400 Check gauges, and low gas... 08-24-2010, 12:05 AM
STE2400 Re: Check gauges, and low gas... 09-01-2010, 11:20 PM
Fivefingerdeathpunch Re: Check gauges, and low gas... 09-01-2010, 11:25 PM
STE2400 Re: Check gauges, and low gas... 09-03-2010, 01:34 AM
Fivefingerdeathpunch Re: Check gauges, and low gas... 09-03-2010, 01:45 AM
TheOtherNick Re: Check gauges, and low gas... 09-03-2010, 12:37 PM
TLSheff Re: Check gauges, and low gas... 09-03-2010, 02:55 PM
STE2400 Re: Check gauges, and low gas... 09-03-2010, 11:25 PM
helmutdog Re: Check gauges, and low gas... 02-19-2011, 09:09 AM
  1. #1 Check gauges, and low gas warning light problem
    Jun 2010
    Kalamazoo MI
    These two indicator/ warning lights have been on since the very first day I've owned the car, and the gas warning light stays on even with a full tank. Any ideas as to what might be causing this problem?
  2. #2 Re: Check gauges, and low gas warning light problem
    Jun 2010
    Kalamazoo MI
    Anyone?
  3. #3 Re: Check gauges, and low gas warning light problem
    maybe a bad fuel level sensor
  4. #4 Re: Check gauges, and low gas warning light problem
    Jun 2010
    Kalamazoo MI
    I'm not to sure, the gauge still reads how much fuel I have or don't have.
  5. #5 Re: Check gauges, and low gas warning light problem
    hmm, then its not that. Im kinda out of ideas, maybe someone else will chime in
  6. #6 Re: Check gauges, and low gas warning light problem
    Charles City, IA
    Could be a bad ground somewhere.
    SMGPFC Two Nipple General
  7. #7 Re: Check gauges, and low gas warning light problem
    I live here. TLSheff's Avatar
    For starters, what kind of car are you working on? I.E. year model, SE, GT, GTP, etc...
    Id agree possible grounding issue. Is the low fuel light on cluster lit up or is it the DIC above the radio on the dash? more details would be very helpful
  8. #8 Re: Check gauges, and low gas warning light problem
    Jun 2010
    Kalamazoo MI
    It's A 1992 GP STE 3.4 liter auto
    The only dash lights that come on and never go out are the orange gas light next to the fully functional actual gas gauge and the check gauges light. It also does it on the digital display of my newly installed HUD unit I found at the junk yard the other day.
  9. #9 Re: Check gauges, and low gas warning light problem
    Altus, Ok
    I have the same issue with a 92 GP LE 3.1
    Now this car was abused and has sat under a tree for the past 2 yrs.
  1. check gauges and battery light on
    By gtpwilson in forum General Tech Discussion
    Last Post: 10-30-2011, 06:01 PM
  2. ABS Light+Low Trac+Check Tire Pressure Problem
    By 1997gpgt in forum Brakes/Suspension/Chassis
    Last Post: 08-11-2011, 10:18 PM
  3. warning light
    By theextreem in forum Shops and Community Heroes
    Last Post: 03-06-2010, 02:01 PM
  4. 2004 GP gauges stop working and warning messages come on
    By mark1491 in forum General Tech Discussion
    Last Post: 12-20-2009, 02:18 AM
  5. ABS warning light
    By BankRupt in forum General Tech Discussion
    Last Post: 07-15-2008, 12:48 AM
