Thread: Brake Warning Light
Results 1 to 20 of 21
  1. #1 Re: Brake Warning Light
    check your pads for wear, and look at the top of the parking brake lever for the plunger/sensor, it may be sticking or dead, thus keeping your brake light on, my regals used to stick and stay on.
  2. #2 Re: Brake Warning Light
    Jun 2011
    Detroit, MI
    He said it felt like he was braking when he pressed the brake, so it wouldn't be the e brake. Pads wouldn't set off the light.
    iLoveSpade
  3. #3 Re: Brake Warning Light
    as your pads wear the fluid drops, but the op says the fluid is full. and a mushy pedal would make the brake light come on too, could be bad master cylinder or air in the lines, but op says he has a firm pedal.... then says the brakes seemed to fade i guess under "HBS" aka "heavy braking situation" so check for pad wear, unless the pedal hit the floor. then air in the lines or master cylinder.
  1. Check gauges, and low gas warning light problem
    By STE2400 in forum General Tech Discussion
    Last Post: 02-19-2011, 09:09 AM
  2. Trac off light, Brake light on?
    By 1badregal in forum Brakes/Suspension/Chassis
    Last Post: 10-17-2010, 10:24 AM
  3. Water in LR brake light housing/ABS light
    By andante147 in forum General Tech Discussion
    Last Post: 05-31-2010, 08:01 PM
  4. warning light
    By theextreem in forum Shops and Community Heroes
    Last Post: 03-06-2010, 02:01 PM
  5. ABS warning light
    By BankRupt in forum General Tech Discussion
    Last Post: 07-15-2008, 12:48 AM
