Thread: Struts, Tie Rods, Sway Bar $578 Quote
Results 1 to 10 of 10
  1. #1 Struts, Tie Rods, Sway Bar $578 Quote
    SE Level Member 01STOCKGTP's Avatar
    Nov 2010
    Michigan
    So i heard a thump in the front end a couple days ago. I brought it in and they jacked it up and told me i need new struts, tie rods, and a sway bar. They quoted $303 for struts, 136 for tie rods, and 98 for a sway bar all including labor to install.
    Is this a fair price?
    Do i really need a new sway bar if mine isn't cracked? ... which i would assume it isn't
    Could i install these myself? Im a fairly handy 19 year old who likes getting bloody knuckles if itll save me some dough
    Thanks guys
  2. #2 Re: Struts, Tie Rods, Sway Bar $578 Quote
    Take a look at Rockauto for the pricing on the parts. Struts are probably a 2-3 hour labor charge, Sway is about an hour and tie rods ..eh..another hour.
    The clunk you hear is likely the sway bar. You drive a W body.. it's nearly a given if it's stock. As for the struts and tie rods, you should feel like the car isn't handling the road overly well and the tie rods should make your wheel not respond right away.
  3. #3 Re: Struts, Tie Rods, Sway Bar $578 Quote
    Nov 2010
    Michigan
    called the mechanic up and its just the sway bar bushings that needed replacement not the whole sway bar
  4. #4 Re: Struts, Tie Rods, Sway Bar $578 Quote
    IL
    sway bar bushings shouldn't be that hard to replace yourself, you might get a little dirty but its better than paying labor cost...
  5. #5 Re: Struts, Tie Rods, Sway Bar $578 Quote
    You'll need an alignment regardless.
  6. #6 Re: Struts, Tie Rods, Sway Bar $578 Quote
    Ocala, FL
    In a ten year old car, you probably do need struts, I doubt they're responsible for your clunk though.
    You can do struts yourself, hardest part is compressing the spring. You could either rent a compressor(free, essentially) from autozone or similar, or pay someone to build your strut assembly.
    Sway bar could be broken, simple enough to check. If it is, may as well upgrade to a gmpp or another beefier than stock bar.
  7. #7 Re: Struts, Tie Rods, Sway Bar $578 Quote
    Charles City, IA
    There is no point to replace just the strut. Get a quick strut with everything then it is just bolt in. That prices seems pretty good for all the parts installed and just an FYI the sway bars on the Wbody had like a 70% failure rate.
    SMGPFC Two Nipple General
  8. #8 Re: Struts, Tie Rods, Sway Bar $578 Quote
    GT Level Member Dtrick22's Avatar
    Jul 2010
    Holyoke, MA
    The price doesn't seem bad but the only thing that jumps out is $98 to replace sway bar bushings??No, don't let them do that. Moog bushings are like $6, Poly swaybar endlinks are somewhere around $20
    2006 GT- S1x, 3.25 MPS, Lucas 42.5, MAF, SD Headers, C5 Brakes, AGX/Vogtland, GMPP sways
    Quote Originally Posted by Wotgtp View Post
    I eat, drink, sleep, and masterbate to grand prix's. Come at me bro.
  9. #9 Re: Struts, Tie Rods, Sway Bar $578 Quote
    SE Level Member postalc38's Avatar
    Brant, Michigan, United States
    Yep, if it's just the sway bar links you can get away with a $10 part an no labor, and is probably the easiest suspension repair for someone who doesn't know too much. I know you'd rather put that other $90 in your gas tank.
    Where in Michigan are you at?
    2000 GP - 157K (DD/Crash damaged project)
    1995 Olds Aurora L47 - 222K
  10. #10 Re: Struts, Tie Rods, Sway Bar $578 Quote
    Nov 2010
    Michigan
    grand rapids. i go to college in georgia tho so thats where i got the quote
  1. Joke of the day, Quote of the day.
    By shawngtp in forum Off Topic Discussion
    Last Post: 12-13-2012, 05:49 PM
  2. Just to quote the movie taken
    By nyydmb12 in forum The Rant Forum
    Last Post: 05-14-2010, 08:41 PM
  3. rods
    By musiknjoyr in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-28-2009, 08:19 PM
