Thread: ABS/trac off lights on - 2002
Results 1 to 9 of 9
  1. #1 ABS/trac off lights on - 2002
    Dec 2010
    MN
    A local shop hooked up the scan tool and said the scan tool and brake module were not communicating with each other. Any Ideas? The shop said they could start trial and error fixes at $85 an hour. What can I try on my own. I usaully can handle most avereage mechanical/electriacal work myself. What should I do next???
  2. #2 Re: ABS/trac off lights on - 2002
    let's toast til we die brand121's Avatar
    South Carolina
    Check the ABS fuse in the fuse box under the hood...
    My couch pulls out, but, I don't...
  3. #3 Re: ABS/trac off lights on - 2002
    Dec 2010
    cny
    99percent of the time when those come on together its a ABS tone ring problem wich is fixxed by replaceing the wheel bearing where the tone ring is bad or could be a sensor itself , without knowing what kind of scan tool they used they could be BSing you
  4. #4 Re: ABS/trac off lights on - 2002
    SE Level Member iluvbst's Avatar
    kissimmee,fl
    Just wanted to know if u have fixed the problem yet? I'm having the same exact problem...
  5. #5 Re: ABS/trac off lights on - 2002
    Attleboro, Ma
    Fwiw my car has a similar problem. I've replaced the bearing. Try as much of a pain in the as that it is try the EBCU. Go to morad, it's about 200 bucks. Look into that. Hope this helps.
  6. #6 Re: ABS/trac off lights on - 2002
    SE Level Member kyrebel's Avatar
    Dec 2010
    Louisville, Kentucky, United States
    i've got an 04 gtp have both the abs and traction lights on was told it was my hub so i replaced both of the front hubs and still throwing the same lights any ideas for an 04?
  7. #7 Re: ABS/trac off lights on - 2002
    Attleboro, Ma
    Could be the same thing. The EBCU brakes in most w-f bodies from what I've read. Definitely do some research on it. My car is definitely the EBCU, l maybe it's the same for you guys. i'll try to get the codes so you guys can compare
  8. #8 Re: ABS/trac off lights on - 2002
    Attleboro, Ma
    C0244 PWM Delivered Torque Malfunction, C0550 ECU Malfunction
    These are the codes i got maybe you guys have the same. If you do its definately the EBCU.
  9. #9 Re: ABS/trac off lights on - 2002
    GT Level Member Lougp05's Avatar
    Long Island,New York
    this happened to my car as well i had to change the passenger front hub assembly and that fixed it,but now it happening again n it sounds like my front driver side
    <>Lou<> 05 GP,Black,8000k HIDS,FLowmaster Exhaust,Intake,20% tints.
  1. "abs" and "trac off" lights staying on?
    By john9472 in forum Brakes/Suspension/Chassis
    Last Post: 12-03-2013, 09:38 PM
  2. ABS/Trac Off Lights on
    By trailshredder in forum Brakes/Suspension/Chassis
    Last Post: 10-31-2010, 05:59 PM
  3. ABS and Trac Control Lights On
    By itfrg in forum Brakes/Suspension/Chassis
    Last Post: 04-05-2010, 03:07 PM
  4. Hit pothole..now ABS and TRAC OFF lights stay on
    By abuckley1290 in forum General Tech Discussion
    Last Post: 06-15-2009, 11:07 PM
  5. ABS and trac off lights
    By probuilder1 in forum Brakes/Suspension/Chassis
    Last Post: 03-12-2009, 06:31 AM
