Thread: rear brakes
Results 1 to 20 of 22
  1. #1 Re: rear brakes
    meh, larger rotors and pads mean higher thermal capacity.
    The ratio between your master cylinder and your caliper pistons determine brake force.
    Caliper rigidity also effects how efficiently the force is transferred.
    But pad composition plays a large part as well.
    Before ALL of that is what you have for traction.
    namely your tires.
  2. #2 Re: rear brakes
    GTX Level Member Deimos's Avatar
    iowa
    the DOT sythetic fluid has awesome prperties to handle heat
  1. GXP Rear Brakes
    By TMC in forum General Tech Discussion
    Last Post: 05-11-2009, 11:46 AM
  2. 2004 GTP rear brakes
    By NSUstud in forum Brakes/Suspension/Chassis
    Last Post: 03-18-2009, 08:06 PM
  3. Rear brakes dragging
    By DRWBRTq19 in forum Brakes/Suspension/Chassis
    Last Post: 10-01-2008, 10:44 PM
  4. What rear brakes fit?
    By Berger in forum Brakes/Suspension/Chassis
    Last Post: 07-29-2008, 11:46 AM
