Thread: rear brakes
Results 1 to 20 of 22
  1. #1 rear brakes
    Attleboro, Ma
    Just wondering in a scheme to save money, has anyone tried to use stock front calipers and rotors for rear brakes? I know you'll have to disable the e brake cause it won't work. I was thinking of upgrading to f body brakes for the front and if I could run my front brakes as rears. Any input?
    -Ray
  2. #2 Re: rear brakes
    unless you plan on lowering the car, moving weight to the back and having a much stiffer suspension its just a bad idea in terms of brake balance.
  3. #3 Re: rear brakes
    Attleboro, Ma
    Even with dual piston in front?
  4. #4 Re: rear brakes
    the size of the piston determines the force.
    two smaller pistons lets you run a larger pad.
    You'd want to maintain the brake bias.
  5. #5 Re: rear brakes
    I believe in some states you also have to have a working E-brake to pass Inspection. and I think Mass is one of them
  6. #6 Re: rear brakes
    For your state....disconnecting the e-brake will cause this
    My Anti-lock brake light is on, am I going to fail inspection?
    No, anti-lock brakes are not part of the state inspection. However, if the brake light is on, indicating a failure in the hydraulic braking system, you will be failed. This indicates a serious condition which must be checked immediately. The anti-lock brake light indicates a problem with that specific feature of your braking system. We do, however, suggest you have the brakes checked as soon as possible.
  7. #7 Re: rear brakes
    Attleboro, Ma
    Yeah that sucks lol, if the ebrake could be ran to the caliper that would be nice. But I cant with these. Oh well was a good thought.
    In an other question, Do I really need a F-body front brake upgrade or can i use the standard 12 inch upgrade that uses stock calipers? How big are the rear rotors?
  8. #8 Re: rear brakes
    you could just switch to 12" rotors.
    retain your calipers.
    better braking.
  9. #9 Re: rear brakes
    Attleboro, Ma
    better braking.
    ....and cheaper
    I thought most of the breaking power came from the Dual Piston mor than the rotor
  10. #10 Re: rear brakes
    meh, larger rotors and pads mean higher thermal capacity.
    The ratio between your master cylinder and your caliper pistons determine brake force.
    Caliper rigidity also effects how efficiently the force is transferred.
    But pad composition plays a large part as well.
    Before ALL of that is what you have for traction.
    namely your tires.
  11. #11 Re: rear brakes
    GTX Level Member Deimos's Avatar
    iowa
    the DOT sythetic fluid has awesome prperties to handle heat
  12. #12 Re: rear brakes
    most people dont even bleed their brakes regularly lol.
    Just run DOT 4 and you should be okay if you're flushing it every two years.
    The last place the heat should be is in the brake fluid.
    DOT 3 205 °C (401 °F)
    Steet pads are generally good for up to 750-800 IIRC.
    Hmm....
  13. #13 Re: rear brakes
    Attleboro, Ma
    Something else I need to flush this spring. I didn't realize that the fluid actually got hot lol
  14. #14 Re: rear brakes
    Do the GXP rear brakes :gotme:
    The GXP rear brake rotor is vented
  15. #15 Re: rear brakes
    fluid really doesn't get that hot.
    Dry boiling point Wet boiling point
    DOT 3 205 °C (401 °F) 140 °C (284 °F)
    DOT 4 230 °C (446 °F) 155 °C (311 °F)
    DOT 5 260 °C (500 °F) 180 °C (356 °F)
    DOT 5.1 270 °C (518 °F) 190 °C (374 °F)
    If it does, it boils over and you need new fluid immediately.
    Only happens in racing or similarly aggressive driving.
    +1 for the rear GXP upgrade.
    Question is, can you fit it under 16's.
  16. #16 Re: rear brakes
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    Quote Originally Posted by Matt5112
    Yes you can, they fit under a snowflake and others, just won't fit under the crosslace wheels at least the rears.
  17. #17 Re: rear brakes
    Attleboro, Ma
    Gxp brakes will fit but there 600 beans
  18. #18 Re: rear brakes
    Apr 2009
    Carlisle PA
    Quote Originally Posted by ray03gtp View Post
    Ray, actually they can be found cheaper. I brought brand new calipers and brackets for $175 shipped. The rotors I bought from R1 Concepts, drilled and slotted for $175 also. So for the full setup I have $350 total into it (minus the lines and pads).
    You may have to do some creative searching to find a pair new or it's easier to find used, but 600 is way over what is needed to be spent.
  19. #19 Re: rear brakes
    Attleboro, Ma
    nice i will look into that ty
  20. #20 Re: rear brakes
    I would have to change my rear hub...lame
  1. GXP Rear Brakes
    By TMC in forum General Tech Discussion
    Last Post: 05-11-2009, 11:46 AM
  2. 2004 GTP rear brakes
    By NSUstud in forum Brakes/Suspension/Chassis
    Last Post: 03-18-2009, 08:06 PM
  3. Rear brakes dragging
    By DRWBRTq19 in forum Brakes/Suspension/Chassis
    Last Post: 10-01-2008, 10:44 PM
  4. What rear brakes fit?
    By Berger in forum Brakes/Suspension/Chassis
    Last Post: 07-29-2008, 11:46 AM
