Thread: What is the widest tire you can fit on stock height, AND lowered 1.4"
Results 1 to 20 of 33
  1. #1 What is the widest tire you can fit on stock height, AND lowered 1.4"
    GT Level Member comatoast's Avatar
    Nov 2012
    MN
    Car is stock height and heels now, but looking at getting rid of some of that wheel gap, and possible go to a wider tire as the 225/55/17s on there look dumb to me, just to narrow for a big wide car.. So If I was leaving it stock height, Could I fit something like a 235/50 or 245/50? Rims will be in the future as well, but for now I'll stick with just trying to figure out what I can and can't do
    Also if I do lower it, I was looking at these springs, and was wondering if anyone had any suggestions .. These say 1.4" drop
    .:: Vogtland Sport Springs ::.
  2. #2 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    Ontario
    Yes. I fit 18x8's with 1.8" drop and 245/45's.
    Even when I have three hookers in the backseat, it's all good.
  3. #3 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    Nov 2012
    MN
    Quote Originally Posted by Oxfire View Post
    Thats all thats important!!
    Shoulda mentioned tho, my car is an 06, Dunno if that would limit my options, or amount of hookers..???
  4. #4 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    Ontario
    Quote Originally Posted by comatoast View Post
    Same shiet. Ratio of hookers to seat is the same. Bio used to run 19's without rubbing I believe.
  5. #5 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    I live here. TLSheff's Avatar
    28x10s
  6. #6 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    Nov 2012
    MN
    28x10s
    No way I could do that...
    Im white
  7. #7 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    You're suppose to say I prefer a different style
  8. #8 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    If you get the proper wheel with just the right offest you can do 18x9 - 18x9.5, but you'd defintely have to roll the fenders. 18x10s are doable if you don't mind some camber adjustments and suspension upgrades, but not so easy.
    Most look into 18x8s with a +30ish offset and call it a day, pretty flush and a good agressive look when lowered.
  9. #9 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    Probably 10" wide wheels, tires around 275...but then you add weight
    A size setup is 8.5" wide wheels with 245s
  10. #10 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    Nov 2012
    MN
    Quote Originally Posted by Drunkie View Post
    Glad U posted, Because It was the car in your sig that made me consider Lowering my car lol
  11. #11 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    Nov 2012
    MN
    Thanks man, Ill look more into it later, but It would probably just be a 18x8 .. nothing fancy
  12. #12 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    Arizona
    285/40/18's will fit but like posted above after 275 youre just adding weight unless your pushing some serious power and need every mm of tread you can get.
  13. #13 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    who the hell would run anything over a 255 on a grand prix unless you really needed the traction? that's just stupid and a waste of money.
  14. #14 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    GT Level Member addzradd's Avatar
    Feb 2010
    Cleveland
    I run 275/50/17's on cobra rims on track days and never have issues rubbing.
  15. #15 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    Nov 2012
    MN
    Im not trying to go super wide... Just wide(er)
    Looking like 245/50/17 is a close match.. But I reeaaalllly wanna get rid of the wheel gap.. Anyone have alignment issues with SSC or Vogtland?
    Seeing as how most places align of factory specs, I just dont want it to be an issue
  16. #16 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    you should be fine. those springs dont lower enough to not be correctable.
  17. #17 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    Nov 2012
    MN
    Thank u sir... Any suggestions or recommendations on the better spring, or are they pretty similar?? I check the Lowering thread, but it didnt say much on the vogtland springs
  18. #18 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    vogtlands are better springs since they are a fairly commonly used OE company. SSC will go lower, but they're gonna ride more rough.
    you don't really want to hear my opinion about what you should do, though.
  19. #19 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    Arizona
    Thats the point...for traction.
  20. #20 Re: What is the widest tire you can fit on stock height, AND lowered 1.4"
    bigger than a 255 requires wide wheels to compensate for the width of the tires in order to use those tires properly? who do you know that does that? okay then.
  1. Stock Ride Height - 04 GP
    By jmoore4294 in forum Brakes/Suspension/Chassis
    Last Post: 07-20-2011, 07:07 PM
  2. Widest rim you can run on a 225/50/18 tire?
    By Bluemagic in forum Tires & Wheels
    Last Post: 02-04-2011, 06:37 PM
  3. Stage "height"
    By I800C0LLECT in forum Audio, Security & Visual Electronics
    Last Post: 04-12-2010, 09:07 PM
  4. Stock crome 16" wheel...what size tire?
    By Boosted02GTP in forum Tires & Wheels
    Last Post: 03-04-2009, 09:57 PM
