Thread: Leaking hydraulics - proportioning valve
Results 1 to 13 of 13
  1. #1 Leaking hydraulics - proportioning valve
    Denver
    I've spent the last couple of weeks tracking down and fixing oil leaks in my engine compartment. I've since pressure washed my driveway and have found a brake leak on my now pristine driveway
    I got my trusty inspection mirror and tracked it down to the proportioning valve. It's leaking from the body of the valve itself - the portion where the two halves meet is leaking (not the connection to the brake hose).
    This is the first time I've ever seen a proportioning valve leak so I'm wondering if this is a common failure.
    Have any of the rest of you had proportioning valve issues?
    Also, my Hayne's manual has nothing in it re: the proportioning valve. Other than removing the old one, getting its orientation correct, and bleeding per normal procedure, is there anything else I need to do?
  2. #2 Re: Leaking hydraulics - proportioning valve
    its near the rear brakes right? if so, just buy a new one from the dealer then bleed the brakes.
  3. #3 Re: Leaking hydraulics - proportioning valve
    Denver
    Yup - right next to the fuel filter. If they're not too expensive, I will replace both.
  4. #4 Re: Leaking hydraulics - proportioning valve
    Charles City, IA
    Just replace the lines while you are doing it. They will probably break anyways. Should only be like $30 for the lines and fittings.
    SMGPFC Two Nipple General
  5. #5 Re: Leaking hydraulics - proportioning valve
    Denver
    Are you talking about the hard lines or the flex lines? I replaced the flex hoses with braided lines a while ago.
    I'm going to pressure bleed my brakes again tonight - I'm not sure I got all the air out last night (plus I only did the back circuit). I would have done all four but I ran out of time when my pressure bleeded blew a hose and spewed brake fluid all over my garage
  6. #6 Re: Leaking hydraulics - proportioning valve
    There is no back circuit.
    Its front left and rear right on a circuit and front right and rear left on a circuit.
  7. #7 Re: Leaking hydraulics - proportioning valve
    Denver
    Good to know - I assumed each wheel had a separate circuit given the 4 hoses exiting the ABS assembly.
    Even more reason to re-bleed the entire system.
  8. #8 Re: Leaking hydraulics - proportioning valve
    Technically yes, each corner has its own circuit after ABS but before abs theres two.
  9. #9 Re: Leaking hydraulics - proportioning valve
    Denver
    Right - it looks like out of the master it's two in an x-pattern then split into four.
  10. #10 Re: Leaking hydraulics - proportioning valve
    yup
    I can post the ABS diagram if you want.
    Its in the GM service manual over on GPONA.
  11. #11 Re: Leaking hydraulics - proportioning valve
    Denver
    If you have it handly, by all means.
    I was using this as a reference. It has the same modulator assembly as mine (Bosch 5.3)
  12. #12 Re: Leaking hydraulics - proportioning valve
    (1) Master Cylinder
    (2) Master Cylinder Reservoir
    (3) Pump
    (4) Left Front Master Cylinder Isolation Valve
    (5) Left Front Prime Valve
    (6) Brake Pressure Modulator Valve (BPMV)
    (7) Damper
    (8) Right Rear Inlet Valve
    (9) Accumulator
    (10) Right Rear Brake
    (11) Right Rear Outlet Valve
    (12) Left Front Outlet Valve
    (13) Left Front Brake
    (14) Left Front Inlet Valve
    (15) Left Rear Inlet Valve
    (16) Left Rear Brake
    (17) Left Rear Outlet Valve
    (18) Right Front Brake
    (19) Right Front Outlet Valve
    (20) Accumulator
    (21) Right Front Inlet Valve
    (22) Damper
    (23) Right Front Master Cylinder Isolation Valve
    (24) Right Front Prime Valve
  13. #13 Re: Leaking hydraulics - proportioning valve
    Apr 2011
    sudbury
    i remove the porportioning valves on my grand prix thinking i don t need them as they were leaking.... i wanted to know if its a need to have them. and now i cant bleed my system.... i have steady fluid sprying out through the bleeder screww nicly all around but the peddle is mush.... any ideas guys? thanks
  1. Leaking Oil ?
    By Blacknight02GT in forum General Tech Discussion
    Last Post: 12-30-2010, 11:29 AM
  2. low oil sensor leaking.....
    By Scottydoggs in forum General Tech Discussion
    Last Post: 08-31-2010, 08:55 PM
  3. leaking air
    By nyydmb12 in forum Tires & Wheels
    Last Post: 07-14-2009, 07:39 AM
  4. S/C Leaking???
    By jagamite in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-02-2008, 08:53 PM
  5. sunroof still leaking
    By 99prixgt in forum General Tech Discussion
    Last Post: 08-27-2008, 12:32 AM
