Thread: random brake rubbing under 20mph
Results 1 to 12 of 12
  1. #1 random brake rubbing under 20mph
    Jun 2010
    Austin, TX
    question for you guys.
    just did a brake job on a very limited budge.... I spent $40 and got rotors and pads. But here is the kicker the rotors where the best they had in stock and the pads are EBC red stuff. Also got the hardware ie clips and boots. the only thing I havent changed out is the bolts on the caliper and the caliper.
    the reason the pads were almost new used for 6 months but they turned the rotors before I got the car and messed them up so it vibrated while braking. Also when going under 20 mph there was and still is a random rubbing coming from the brake some times it trips the ABS light.
    Do you think its just the bolts that need to be cleaned and or replace or....Do you think its the caliper
    if I have to replace the calipers I am going to upgrade to the 12'' from ZZP
    please let me know I got a 1300 mile drive coming up in 2 weeks then another 1300 home after a week and a half..
    Thanks for your input
  2. #2 Re: random brake rubbing under 20mph
    Charles City, IA
    That could be a wheel bearing grinding, jack it up and check for play.
    SMGPFC Two Nipple General
  3. #3 Re: random brake rubbing under 20mph
    if you didn't remove the guide pins and clean and regrease them that could be your problem.
    But as nick said, could be a bearing as well.
    Rubbing from brakes would sound well like your brakes. Does it sound like that?
  4. #4 Re: random brake rubbing under 20mph
    SE Level Member 98GTPV8etr's Avatar
    Nov 2010
    Petawawa Ontario Canada
    are the rotors warped?
  5. #5 Re: random brake rubbing under 20mph
    Jun 2010
    Austin, TX
    I know the sound is coming from the brakes.
    I jacked up the car and checked for play nothing. I did find play in the mirror since I'm Lord4play hahahaha.
    didn't clean the pins I was running out of time and I was already out of brake cleaner.
    the rotors and pads are brand new the old ones where warped.
    This Saturday I'm going to a friends house to work on the brakes and maybe a little exhaust work. I might weld in a glasspack to see if it changes the tone any.
    right now running stock exhaust manifolds, no cat, no res, stock mufflers depending on how much money I got left I might put different mufflers on too.
    not sure what kind of mufflers
    magnaflows
    flowmaster 40s
    cherrybomb pro or elites maybe the red extremes
    I will probably go cheap since I will be replacing it again once I get headers
  6. #6 Re: random brake rubbing under 20mph
    no flows EVAR
  7. #7 Re: random brake rubbing under 20mph
    Jun 2010
    Austin, TX
    no flows EVAR
    well what is your suggestion?
    this project starts in 13 hours
  8. #8 Re: random brake rubbing under 20mph
    Borla XS muffs
    Cherry bomb Turbo muffs
    Walker Quietflow muffs... stainless stock sounding love.
  9. #9 Re: random brake rubbing under 20mph
    Donating Users Vegas_Matt's Avatar
    Jul 2010
    Las Vegas, NV
    i got 40's and they're pretty loud when my cat's not clogged up rofl
    <MiZzBeCcA>its not rape if you yell suprise
  10. #10 Re: random brake rubbing under 20mph
    Quote Originally Posted by Lord4play View Post
    WHY??
    u will get mass drone.
  11. #11 Re: random brake rubbing under 20mph
    Jun 2010
    Austin, TX
    well the brake problem is fixed. I didn't do anything to the exhaust. I'm just going to leave it till I get the headers then put a full exhaust on till the car is paid off then it gets a top swap
    but before the next exhaust upgrade I'm going to retrofit a set of bi-xenon projectors.
    a set of Bi-xenon Morimoto Minis I will start a new tread on that once I get them
  12. #12 Re: random brake rubbing under 20mph
    Largo, Florida, United States
    i like the sound of Magnaflow personally
  1. Odd noise / rubbing
    By Elitemonkie in forum General Tech Discussion
    Last Post: 11-06-2010, 08:06 AM
  2. Random brake pedal grinding
    By ptnothere in forum Brakes/Suspension/Chassis
    Last Post: 05-05-2010, 12:25 AM
  3. 'Rubbing' Noise when Backing Up
    By nickbuol in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2009, 10:41 PM
  4. e-brake rubbing inside of rotor
    By popeyenate in forum Brakes/Suspension/Chassis
    Last Post: 08-12-2009, 12:08 AM
  5. Fan rubbing on the radiator
    By Infinity9999 in forum General Tech Discussion
    Last Post: 12-23-2008, 11:43 PM
