Thread: Rack and Pinion Seal replacement
Results 1 to 7 of 7
  1. #1 Rack and Pinion Seal replacement
    GTX Level Member webracin's Avatar
    Arkansas
    Has anyone ever tried to replace the Rack and Pinion seals.
    It appears that I have one leaking on the drivers side, but the rack is working fine. its 40 bucks for the seals or 250 for the rack, so I would like to get this fixed as cheap as possible.
    Thanks
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  2. #2 Re: Rack and Pinion Seal replacement
    PA
    I have never heard anyone replacing the seals on in the rack. Where did you find the seals to buy individually?
    From my best guess, I would say you need to remove the rack to rebuild it. I can't see how you could take it all apart while in the car. So if you are going to go through the 3-4 hours of removing and reinstalling the rack, just put in another one.
    The last rack I put in my car I got from Ed Morad (I would never buy an aftermarket rack from any parts store - only GM racks for me). I believe it was around $75. And that was almost a year ago and 30,000 miles. Still working great! I would suggest you get ahold of Ed and get a rack from him.
    2001 GSE
  3. #3 Re: Rack and Pinion Seal replacement
    Wichita, KS
    Quote Originally Posted by Zef_66 View Post
    I would never buy an aftermarket rack from any parts store - only GM racks for me. I would suggest you get ahold of Ed and get a rack from him.
    Amen.
    Ya life time warranty on the part after market...cause your going to need it in a year or so when this one fails or starts leaking too. LOL But who pays you for your time and labor with the R&R?
    OEM replacement for me as well if that time ever comes.
    ~F~
  4. #4 Re: Rack and Pinion Seal replacement
    Arkansas
    Yea, I think thats the route I am going to go. I found the seals on RockAuto.com
    For the AC Delco seals it was 40 bucks, and thought that was pretty good, but if I have to go thru the trouble of changing out the rack, I think I will get one from Ed, and try and rebuild the one I pull for the next change (since I have 3 GP's still on the road).
    Thanks
    webracin
    2001 Grand Prix GTP
  5. #5 Re: Rack and Pinion Seal replacement
    woodstock ill
    Hello; I'm looking to replace the rack and pinion unit on my 2002 G/P. It was just replaced 3-4 months ago by a school shop, for the cost of parts only. NAPA is warranteeing the parts, but the school no longer has the program. I was a G/M tech years ago, but have never done one of these. Any suggestions?? How long should it take?? Thanks, Dutch
  6. #6 Re: Rack and Pinion Seal replacement
    GTX Level Member Deimos's Avatar
    iowa
    about 1.3 hours if you're slow. 30-45 minutes if you're good, measure your tierod nut distances on each side.
  7. #7 Re: Rack and Pinion Seal replacement
    Apr 2009
    stockton ca
    Our schools g/m sponsored but i dont think id let any of them touch my suspension
    I will just have to do it in my garage and take it to an alignment shop after
  1. 04+ Rack and Pinion replacement [*]
    By UR LOSN in forum How To Write-Ups/Tech Tips
    Last Post: 09-26-2017, 01:31 PM
  2. What happens if you disconnect the Magna Steer?
    By Blown97 in forum Brakes/Suspension/Chassis
    Last Post: 12-27-2012, 08:50 PM
  3. Axle Seal Replacement [*]
    By Metallistar in forum How To Write-Ups/Tech Tips
    Last Post: 01-21-2012, 09:25 PM
  4. Power Steering Rack replacement 98 GT
    By Fritcr in forum General Tech Discussion
    Last Post: 04-27-2008, 06:03 PM
  5. Passenger Side Axle Seal Replacement
    By Rob3800 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-30-2008, 04:35 PM
