Thread: inner tie rods
Results 1 to 20 of 21
  1. #1 Re: inner tie rods
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    Quote Originally Posted by Iron Indian View Post
    I assume you need a back up wrench right? Did you need to measure anything with a feeler gauge?
    What is this back up wrench you refer to??? To put the inner tie rod back on you use the same tool you used to remove it. And I didn't use
    any feeler gauge for anything.
    With the variances between manufactures, I just went stop to stop on the steering wheel, set it at halfway and put everything back together.
    I'll adjust it closer when it comes time for the alignment.
  2. #2 Re: inner tie rods
    SE Level Member hondo's Avatar
    Salt Lake City, Utah
    im doing my inner passenger and i cant get the boot off its supposed to have a threded clamp but mine doesnt have one. its just solid. do i cut it?
