Thread: 2k GTP ABS/TC lights and no codes??
Results 1 to 12 of 12
  1. #1 2k GTP ABS/TC lights and no codes??
    Jul 2010
    Warrington, PA
    I've been having the lights come on intermittently for weeks now. It seems to only come on when I do a lot of stop and go. When I first start up it's off sometimes. I ohmed out the sensors and all looks normal - resistance changes when I spin the wheels.
    I tool it to AAMCO (nobody else would read it, or they wanted $$) The guy had a giant Snapon scanner and he said there's no codes! Tried it with the ignition on and running. ABS/TCS lights were on the whole time.
    I am debating just randomly changing the hubs or taking it to the stealership for a diagnosis.
    Any other suggestions?
  2. #2 Re: 2k GTP ABS/TC lights and no codes??
    Nov 2009
    Grand haven
    ABS mod going bad I had the same thing happen just get one from the local yard or someon on here.
  3. #3 Re: 2k GTP ABS/TC lights and no codes??
    SE Level Member e6600's Avatar
    Los Angeles
    Quote Originally Posted by shawngtp View Post
    i know it would matter what year you pull it off of, but will it matter if you pull the abs unit from a different 3800? like from a 00 regal ls
    98 grand prix gtp: stock until i fix problems
  4. #4 Re: 2k GTP ABS/TC lights and no codes??
    Jul 2010
    Warrington, PA
    Thanks.
    Does anyone know if the module is just a computer that can be simply unplugged, or are we talking about a unit with lots of brake lines going in a nd out of it, connected to the master cylinder?
    I've done both just hoping it's a computer swap!
  5. #5 Re: 2k GTP ABS/TC lights and no codes??
    GT Level Member gpbastard's Avatar
    Florida
    i have the same thing going on with my car as far as the ABS/TCS light going on sometimes. I looked through my Alldata and couldn't find the an ABS mod. What part are you referring to. is it the EBCM, (electronic brake control module)?....
    gpbastard
  6. #6 Re: 2k GTP ABS/TC lights and no codes??
    Jul 2010
    Warrington, PA
    It may be referred to as the EBCM. Here's a link to it:
    CHEAP ABS Module Repair for Pontiac Grand Prix
    I have the factory manuals, but I stopped reading when it said I needed a special scanner. I read the boards here and read how to ohm-out the wheel sensors. Then I stopped at AAMCO to get the ABS codes read.
    Since I had no codes, the ABS/Trac light, and the wheel sensors appeared to work, I was told it was probably the module.
    I sent the module out to cheapabs.com and got it back and it's been running 2 days so far (fingers crossed)
  7. #7 Re: 2k GTP ABS/TC lights and no codes??
    Jul 2010
    Warrington, PA
    By the way - I picked a used ABS module and pump from a 97 - 03 GP GT - not knowing that the GTP uses a different module.
    I'd be willing to sell it for what I paid for both parts - $30.
  8. #8 Re: 2k GTP ABS/TC lights and no codes??
    Florida
    Quote Originally Posted by torqueaddict View Post
    do you have the part #? i need one for an 01 GP SE. the module only part # for that year is 12458914. let me know..
    gpbastard
  9. #9 Re: 2k GTP ABS/TC lights and no codes??
    Jul 2010
    Warrington, PA
    Quote Originally Posted by gpbastard View Post
    I am thinking that's the GM part # and does not correlate directly to the codes on the module. The code on the one I have is
    KC
    92 2919 B 24DLT7
    on the bottom it is BOSCH 476 976 51189 5
    By the way - 4 days and no codes since the place I mentioned repaired my module so that's an option too
  10. #10 Re: 2k GTP ABS/TC lights and no codes??
    GTX Level Member colindunn's Avatar
    Aurora, IL
    yeah mine is bad too. the junk yard wanted 150$ for it. which i guess is good considering its like 800$ new... but it has to be from a gtp. i am not sure about other vehicles that have the same engine though. id just find one from a gtp to be safe.
  11. #11 Re: 2k GTP ABS/TC lights and no codes??
    Florida
    KC
    92 2919 B 24DLT7
    mine says 92 2910 b on it. i couldn't get to the bottom of the module to read it because it's still on the car. i'll probably get it rebuilt like your's or get one off ebay from a donor car. sound's like your's might be fixed. this is a very vexing problem. thank's for the info. much appreciated...
    gpbastard
  12. #12 Re: 2k GTP ABS/TC lights and no codes??
    Florida
    Quote Originally Posted by colindunn View Post
    try ebay. they have quite a few on there. about $100.00 or so...
    gpbastard
  1. Head lights and dash lights randomly shut off
    By TheOtherNick in forum General Tech Discussion
    Last Post: 04-01-2020, 05:45 AM
  2. Replies: 0
    Last Post: 03-07-2010, 09:14 PM
  3. Replies: 3
    Last Post: 01-16-2010, 07:19 PM
  4. dim lights not working, bright lights ok
    By madmex2k in forum General Tech Discussion
    Last Post: 12-07-2009, 11:27 PM
