my tires have been wearing badly and belle tire used bolts to adjust but it only works great until i hit a bump and then its back to normal.. i need a pair that wont move the camber angle at any time.. any ideas?
Not sure what u mean
Oval the upper bolt holes on the strut so that you can adjust the angle that the knuckle bolts to the strut and then use stock bolts.
Oh good idea! Would it b ok to drill another hole in the strut support to put a smaller bolt behind the knuckle so it will stop from re aligning when hitting a bump?
For camber all you have to do is grind the upper bolt hole on the bottom of the strut. Not the top strut plate.
