Thread: Are Camber Bolts Needed?
Results 1 to 4 of 4
  1. #1 Are Camber Bolts Needed?
    SE Level Member dhall9's Avatar
    OKC
    Title says it all. I'm planning on lowering my car with a set of vogtland springs (that are still on order from germany). So will I need to install camber bolts while I have everything apart in order to get everything aligned at the shop or can I get away with not having them?
    Thanks for the advice.
    2002 GTP Coupe - Motosports CAI, 3" ZZP DP, GMPP sway bars, ZZP Front & Rear STB's, AL 104's, 180* Tstat
  2. #2 Re: Are Camber Bolts Needed?
    Apr 2009
    stockton ca
    Yes you will need a camber kit to do almost any alignment work on your car
  3. #3 Re: Are Camber Bolts Needed?
    OKC
    Cool, that's what I was needing to know.
  4. #4 Re: Are Camber Bolts Needed?
    May 2008
    McHenry IL
    yeah you need em =[ 37 dollars a bolt what a scam haha
  1. To adjust camber.......
    By trenaro in forum Brakes/Suspension/Chassis
    Last Post: 06-17-2009, 02:18 AM
  2. Camber
    By SlowM90 in forum Tires & Wheels
    Last Post: 05-14-2009, 06:01 PM
  3. camber bolts
    By nemesis in forum General Tech Discussion
    Last Post: 02-29-2008, 05:10 PM
