Thread: looking for a good pair of camber bolts!
Results 1 to 7 of 7
  1. #1 looking for a good pair of camber bolts!
    detroit
    my tires have been wearing badly and belle tire used bolts to adjust but it only works great until i hit a bump and then its back to normal.. i need a pair that wont move the camber angle at any time.. any ideas?
  2. #2 Re: looking for a good pair of camber bolts!
    Charles City, IA
    grind the struts out and use stock bolts.
    SMGPFC Two Nipple General
  3. #3 Re: looking for a good pair of camber bolts!
    detroit
    Not sure what u mean
  4. #4 Re: looking for a good pair of camber bolts!
    Donating Users
    South Deerfield, MA
    Oval the upper bolt holes on the strut so that you can adjust the angle that the knuckle bolts to the strut and then use stock bolts.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  5. #5 Re: looking for a good pair of camber bolts!
    the three bolts that hold the strut in from the top in the engine bay, if you were still unclear.
  6. #6 Re: looking for a good pair of camber bolts!
    detroit
    Oh good idea! Would it b ok to drill another hole in the strut support to put a smaller bolt behind the knuckle so it will stop from re aligning when hitting a bump?
  7. #7 Re: looking for a good pair of camber bolts!
    Charles City, IA
    For camber all you have to do is grind the upper bolt hole on the bottom of the strut. Not the top strut plate.
  1. The New Guy with a Pair
    By mystic231 in forum Introductions/Noob Questions
    Last Post: 07-15-2009, 10:17 AM
  2. Are Camber Bolts Needed?
    By dhall9 in forum Brakes/Suspension/Chassis
    Last Post: 07-05-2009, 09:14 PM
  3. camber bolts
    By nemesis in forum General Tech Discussion
    Last Post: 02-29-2008, 05:10 PM
