Thread: How long should factory struts last?
Results 1 to 8 of 8
  1. #1 How long should factory struts last?
    GT Level Member Madness's Avatar
    Nov 2009
    A little late
    I have recently noticed some new rattling on my 03 GT. It sounds like it is coming from the struts and is more noticable on rough roads. The ride seems a little eratic too.
    How long should the factory struts last?
    Thanks
  2. #2 Re: How long should factory struts last?
    80 000 miles seems to be the "recommended replacement period."
    All depends on who you're talking too.
    In all honesty, shruts age like O2 sensors and tires, they slowly get worse and worse. Difficult to notice over time the decrease in performance.
    How many miles on your car?
    Example: parents acura, took 280 K miles before the rear struts failed, fronts are still going. Factory struts too. Doesnt ride nearly as nice as it could though. Still rides nicer than my GP which is a year newer and has about a third of the mileage on it.
    You can ride them till they break or replace them every 80 K or so to keep your ride quality higher. Up to you.
  3. #3 Re: How long should factory struts last?
    Nov 2009
    A little late
    115,000 miles, just broke in
    It was bought with 74,000 so I am pretty sure they are factory
    Thanks
  4. #4 Re: How long should factory struts last?
    Charles City, IA
    I finally broke a coil spring at 156k.
    SMGPFC Two Nipple General
  5. #5 Re: How long should factory struts last?
    I'd change 'em for good measure. Should ride nicer granted you get OE level struts.
  6. #6 Re: How long should factory struts last?
    Donating User Odi's Avatar
    Chicago South Suburbs
    145 000 miles and still on the oem set of struts and springs. Backs are slowly failing, fronts will live a bit longer, but i am going LOW anyways.
  7. #7 Re: How long should factory struts last?
    Norristown, PA
    What are recommended struts?
  8. #8 Re: How long should factory struts last?
    if youre going stock then get KYB GR2's. If youre plannin on slamming your car with springs (that drop more than vogtlands) then go with KYB AGX.
  1. struts
    By rharper33 in forum Brakes/Suspension/Chassis
    Last Post: 09-28-2009, 12:17 AM
  2. Need new struts
    By hunter_alexander in forum Brakes/Suspension/Chassis
    Last Post: 07-11-2008, 09:41 PM
  3. kyb struts
    By johnnyj773 in forum Brakes/Suspension/Chassis
    Last Post: 05-12-2008, 02:08 PM
  4. Struts
    By bula81069 in forum Brakes/Suspension/Chassis
    Last Post: 05-05-2008, 09:53 PM
  5. Anyone with KYB struts
    By archemedes in forum Brakes/Suspension/Chassis
    Last Post: 03-20-2008, 06:57 AM
