Thread: Ideas for removing trailing arms
Page 2 of 2 FirstFirst 12
Results 21 to 25 of 25
  1. #21 Re: Ideas for removing trailing arms
    Helena, MT
    I just did my trailing arms and I must have been lucky. hardest part was cranking on the breaker bar, then the things popped right out. didn't even need to slap mine with the hammer. best of luck to the o.p. hope the darn things popped out eventually
  2. #22 Re: Ideas for removing trailing arms
    Heat did it.
    Then getting the ****ing bolts out was a giant PITA.
    Sleeve was practically welded to the bolt. Nearly destroyed the bracket trying to get it off.
    All in all, wasn't worth the time I put in.
  3. #23 Re: Ideas for removing trailing arms
    SE Level Member zerolimitsgt's Avatar
    Apr 2009
    Cortland, Ohio
    I know I never woulda bothered changing mine had I not broke a stock one. Although, it was kinda worth it because it stiffened up the rear end.
  4. #24 Re: Ideas for removing trailing arms
    GT Level Member 01gtspecial's Avatar
    Apr 2009
    Georgia
    i used a long ass wrench with a cheater pipe and a dead blow from the other side. i was also concerned with the bushing catching fire so i opted lever arm over heat. a bunch of penetrating oil is necessary and it wouldn't hurt to cut the bushing in multiple places as bushing failure should help in removing the bolt. essentially you have to accept that you need a new bolt. because if the nut is off and the bolt is stuck, you will have marred threads.
    01 GT special ed.: SD hood, GMPP kit, poly sway bushings, Eibachs/Gabriel Ultras, Eagle GTs, ZZP anti-pogo, ZZP short dogbones, ZZP poly trans, ZZP PCM, ZZP HV TB, ZZP HV3, P&P LIM, 4" FWI, 3" DP, custom exhaust, pwdr-coated Trans Am brakes, NGK iridiums, Mobil1 Syn fluids, stage 2 voltage booster, BIG 3, real loud stereo...
  5. #25 Re: Ideas for removing trailing arms
    Nah, saved the bolts.
    Though apparently they're TTY.
    I dont get that at ALL.
  1. GMPP vs. BMR Trailing Arms
    By blkgp2000 in forum Brakes/Suspension/Chassis
    Last Post: 04-17-2010, 09:10 AM
  2. Trailing Arms
    By shawngtp in forum Brakes/Suspension/Chassis
    Last Post: 02-24-2010, 08:56 AM
  3. just an fyi--trailing arms
    By quinnp12 in forum Brakes/Suspension/Chassis
    Last Post: 02-03-2010, 12:38 AM
