Thread: Ideas for removing trailing arms
Results 1 to 20 of 25
  1. #1 Ideas for removing trailing arms
    can't seem to get the damn things off.
    The nut on the hub comes off, but the bolt won't come out.
    Guys at the local shop suggested the bolt is seized to the metal guide inside the bushing and to cut it off or destroy the rubber bushing and get a new bolt.
    Suggestions?
  2. #2 Re: Ideas for removing trailing arms
    GTX Level Member imdaman3's Avatar
    Feb 2010
    ohio
    keep soaking it in penatrating oil, and turnin it and beatin on it with the nut on it thats wat i do takes awhile but works, or use a torch but carefully not to catch the bushin on fire,
  3. #3 Re: Ideas for removing trailing arms
    It wouldnt be ABLE to move if the nut was on it...
  4. #4 Re: Ideas for removing trailing arms
    Feb 2010
    ohio
    just a lil bit so u dont damage the threads wen u hit it out words unless u got a brass hammer the u dont haft to put the nut on
  5. #5 Re: Ideas for removing trailing arms
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    I used a 3/4 inch impact as my 600ft lb of torque 1/2inch wouldnt touch em
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  6. #6 Re: Ideas for removing trailing arms
    Nov 2009
    Grand haven
    I just went through the same thing yesterday on mine. I just kept using my snap on 1/2 impact going foward and then backwards a bunch of times and it broke free. If you don't have an impact then get a brass hammer or punch to knock it out with the nut on even with the face of the bolt as stated above. What trailing arms did you get? I bought the umi or uni ones what ever they are and noitces a huge differance.
  7. #7 Re: Ideas for removing trailing arms
    Jan 1970
    Maquoketa, Iowa
    BFH and a new bolt. Or leave the nut off and drive around until the bolt comes loose
  8. #8 Re: Ideas for removing trailing arms
  9. #9 Re: Ideas for removing trailing arms
    Waconia, MN
    Bend the brake shroud out of the way and give it the BFH x10.
    It let loose
  10. #10 Re: Ideas for removing trailing arms
    Quote Originally Posted by FoSHO99 View Post
    LOL I like this one the most....
    And I have the GMPP ones here.
    I've got two cheap 1/2" impacts, both don't seem to want to do much.
    So its forwards and backwards till I can't hear anything and BFH time.
    But not till tomorrow.
  11. #11 Re: Ideas for removing trailing arms
    Nov 2009
    Grand haven
    LOL. BFH prob willl be your best bet.
  12. #12 Re: Ideas for removing trailing arms
    Donating Users alkygto's Avatar
    Nov 2009
    wentzville
    Apply some heat onto the nut with a propane torch, it will expand the nut slightly. This could make all the difference with the impact wrench. Just dont set your bushing on fire.
    1997 Pontiac Grand Prix GTP
    1969 Pontiac GTO
  13. #13 Re: Ideas for removing trailing arms
    SE Level Member zerolimitsgt's Avatar
    Apr 2009
    Cortland, Ohio
    I had to heat mine with a torch and then hit it with a 3lb mini sledge and the bolt popped right out
  14. #14 Re: Ideas for removing trailing arms
    Wait, is the hole in the hub even threaded?
  15. #15 Re: Ideas for removing trailing arms
    No the hole is not threaded. they just corrode like a mother in there
    98 GTP Stock
  16. #16 Re: Ideas for removing trailing arms
    GTX Level Member 98GTPCALGARY's Avatar
    Feb 2009
    Red Deer AB
    I used a torch and a BFH and my roommate had his foot on a breaker bar... all that together it came out, eventually!
  17. #17 Re: Ideas for removing trailing arms
    not threaded, it does not thread out. you have to just hit it out. its just pushed in there and rusted up.
  18. #18 Re: Ideas for removing trailing arms
    I need new plates for my car, they will read "IMATOOL"
  19. #19 Re: Ideas for removing trailing arms
    Donating Users
    South Deerfield, MA
    Just went through this last week with mine. Passenger side was no problem. Both bolts on the drivers side were rusted solid. Used a torch on the knuckle with a rubber mallet and closed end wrench. Used a dremel with cut off wheels to cut the trailing arm on the bracket side then a knife on the bushing and the dremel again on the bushing sleeve.
    2002 GTP: GMPP Sway Bars, BMR trailing arms, KYB AGX/Vogtlands, 12" brake upgrade
    Modified SSAC headers, K&N Intake, 3.4 MPS, S1X, Gen V, 104's, HPTuned.
  20. #20 Re: Ideas for removing trailing arms
    dayum, Hope the BFH sorts this one out right.
  1. GMPP vs. BMR Trailing Arms
    By blkgp2000 in forum Brakes/Suspension/Chassis
    Last Post: 04-17-2010, 09:10 AM
  2. Trailing Arms
    By shawngtp in forum Brakes/Suspension/Chassis
    Last Post: 02-24-2010, 08:56 AM
  3. just an fyi--trailing arms
    By quinnp12 in forum Brakes/Suspension/Chassis
    Last Post: 02-03-2010, 12:38 AM
