Thread: Hi & front end parts/replacement help
Results 1 to 9 of 9
  1. #1 Hi & front end parts/replacement help
    SE Level Member MichEE's Avatar
    Aug 2008
    Michigan
    Hi gang. New here but have been lurking for a bit. I am impressed (so far) with all of the input on topics I have trolled.
    I am replacing some parts on my '99 GP GT (155K miles!) and would like to have some tips. I need driver's side ball joint, passenger side tie rod sway bar & sway bar links and control arm bushings.
    First, where would you suggest I purchase these parts?
    Second, any suggestions on replacing these parts - should I do more than what is listed or other parts that typically go at this high of miles?
    The vehicle is in great condition - we have had it since 30K and have taken good care of it and just put a new tranny in it.
  2. #2 Re: Hi & front end parts/replacement help
    Feb 2008
    Welcome!!!
  3. #3 Re: Hi & front end parts/replacement help
    Louisville, KY
    My Cardomain
  4. #4 Re: Hi & front end parts/replacement help
    Oklahoma
    Welcome to the community.
  5. #5 Re: Hi & front end parts/replacement help
    Oklahoma
    Moved this into the brakes and handling section.
  6. #6 Re: Hi & front end parts/replacement help
    TDCRacing
    Guest
    www.rockauto.com Use the discount code 11580171007228 for 5% off
  7. #7 Re: Hi & front end parts/replacement help
    Aug 2008
    Michigan
    Thanks for the welcomes!!
    I'll post up some of the decisions I make and let you know what I decide on.
    Thanks for all of the suggestions.
  8. #8 Re: Hi & front end parts/replacement help
    Aug 2008
    Michigan
    See attached - this is where I am at with buying parts so far... does this look right to you that have replaced these parts?
    Question: Why can't I find the complete sway bar?
    Edit: Got the sway bar - thanks Ed!! I'll get the rest of the parts Saturday after I tear apart it all tonight.
    Hi & front end parts/replacement help Attached Files
  9. #9 Re: Hi & front end parts/replacement help
    Aug 2008
    Michigan
    Just finished...
    I got my OEM used sway bar at http://www.moradpartscompany.com/ GREAT service!!
    Here is my helper... he is 4 and knows what a 9/16" is and a 15mm!!
    I got the Moog sway bar links from the local Carquest
    If anyone has a good idea as to how to remove this bolt let everyone know. This as a PAIN!! Only room for 1/8 of a turn.
    wish I would had a torch is all I can say...
    That tie rod end was a bear to remove!!
    I also added some instructions I found.
  1. Front Strut Mount from Advance Auto Parts
    By Abrasive in forum Shops and Community Heroes
    Last Post: 04-02-2009, 11:53 AM
  2. Parts are in for fuel line replacement
    By BlackGS in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-09-2008, 10:00 AM
  3. Replacement Radio LED
    By Deezul_AwT in forum Audio, Security & Visual Electronics
    Last Post: 04-18-2008, 11:35 PM
  4. PVC Valve Replacement (L67) [*]
    By 03GPScottyd in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 06:43 PM
  5. PCV Valve Replacement (L36) [*]
    Last Post: 01-03-2008, 11:25 PM
