Thread: Replacement Radio LED
Results 1 to 11 of 11
Deezul_AwT Replacement Radio LED 04-09-2008, 07:15 PM
nemesis Re: Replacement Radio LED 04-10-2008, 01:46 AM
Deezul_AwT Re: Replacement Radio LED 04-10-2008, 05:29 AM
nemesis Re: Replacement Radio LED 04-10-2008, 01:46 PM
Deezul_AwT Re: Replacement Radio LED 04-10-2008, 06:43 PM
BackInBlack Re: Replacement Radio LED 04-11-2008, 12:08 PM
Deezul_AwT Re: Replacement Radio LED 04-11-2008, 04:00 PM
Deezul_AwT Re: Replacement Radio LED 04-11-2008, 04:36 PM
Deezul_AwT Re: Replacement Radio LED 04-11-2008, 09:04 PM
webracin Re: Replacement Radio LED 04-18-2008, 10:34 PM
Deezul_AwT Re: Replacement Radio LED 04-18-2008, 11:35 PM
  1. #1 Replacement Radio LED
    Donating Users Deezul_AwT's Avatar
    Feb 2008
    Cumming GA
    It appears that the LED on my factory radio is out. Is it replaceable? I just got a cassette player to install for a aux in, and I like the cleaner factory look. So I won't replace the factory deck if I don't have to.
    2016 Ford Fusion Energi Titanium - Still trying to figure out what I can do
    2006 Mercury Mariner Hybrid - K&N Drop in filter. Not much else you can do...
    TOTALED 9/2016 - 2004 Impala SS
    SOLD 3/2013 - 2000 Grand Prix GT
  2. #2 Re: Replacement Radio LED
    chicago
    yes it should be replaceable the led is under metal case. you just have to locate where the led is. here is a 02 gtp radio that the clock light went out. i cut off the top where the led is locate and put in new led. i end up getting another radio cause about 2 months later the clock number was starting to fade off again.
  3. #3 Re: Replacement Radio LED
    Feb 2008
    Cumming GA
    eBay has identical radios for $50-$60, so I may end up going that route. But I'll try the LED route first. Was it a standard light bulb, or something special?
  4. #4 Re: Replacement Radio LED
    chicago
    it's one of them solder on bulb
  5. #5 Re: Replacement Radio LED
    Feb 2008
    Cumming GA
    My luck I'll destroy the radio trying to solder it off and on. Guess I'll live without the display. It disappeared once before, then a few button presses and it came back. Or start bidding on eBay until I get lucky.
  6. #6 Re: Replacement Radio LED
    GT Level Member BackInBlack's Avatar
    Vermont
    @ cutting the radio apart! See my web site. The bulb is easily changed out, even for an LED. You can get a nice 360° LED from SUPER BRIGHT LEDS home
    The GPs are long gone...
  7. #7 Re: Replacement Radio LED
    Feb 2008
    Cumming GA
    Quote Originally Posted by BackInBlack View Post
    I found some AC Delco LED listed on an eBay auction that says it covers my radio. Further research led me to find out GM did use replaceable bulbs originally, but after a few years switched to soldered ones. I'm hoping my radio is one of the older plug in ones; I just have to figure out what bulb type it is once I get the radio off.
    Which LED would I use BackiInBlack? I think the GM one is 914.
  8. #8 Re: Replacement Radio LED
    Feb 2008
    Cumming GA
    Got the light out, it appears to be the replaceable kind. Now I'm hoping to find a local GM dealer that has the part instead of waiting a week for eBay. I'd rather not have to keep putting the dashboard on and off.
  9. #9 Re: Replacement Radio LED
    Feb 2008
    Cumming GA
  10. #10 Re: Replacement Radio LED
    GTX Level Member webracin's Avatar
    Arkansas
    Here ya go....
    16208443
    They are about 9 bucks at the dealership. I think you can get them from GMPARTSDIRECT for about 6, but with shipping your still at the 9 dollar mark. Chances are the local dealer wont carry it, and will have to order it.
    webracin
    2001 Grand Prix GTP
    ZZP HUB 3.2 3.4, ZZP 8 Rib conversion, JC 3" DP Gen 2 cat & U-bend Delete, Accel Super Stock 8mm wires, DHP 1.5, 180* Thermo, Throttle Spacer, SS Intercooler, ZZP Fuel Rails, SLP CAI w/K&N Cone, Dynomax cat back, ZZP Tranny.
    2000 Grand Prix GTP Daytona K&N, Flowmasters
  11. #11 Re: Replacement Radio LED
    Feb 2008
    Cumming GA
    It wasn't the light, or I did something else to the radio when trying to replace the bulb. I got one from Corvetteradios.com, but no light.
  1. Radio is effed up
    By FoSHO99 in forum Audio, Security & Visual Electronics
    Last Post: 04-01-2010, 03:12 AM
  2. Bad Radio Reception
    By hester21289 in forum Audio, Security & Visual Electronics
    Last Post: 02-18-2008, 07:56 PM
  3. How to make a nicer aftermarket radio mounting kit. [*]
    By s1795so2 in forum How To Write-Ups/Tech Tips
    Last Post: 02-18-2008, 10:45 AM
