Thread: Very stiff brake pedal?
Results 1 to 5 of 5
  1. #1 Very stiff brake pedal?
    Donating Users
    Chester County PA
    In moderate weather (below 40 degrees F) when the GP is driven after sitting for 7-8 hrs. the brake pedal is extremely stiff and requires 3 to 4 pumps before it requires normal force to actuate then it works fine. It feels as if the booster is not functioning. Has anyone else had a similar situation? What is the remedy? The GP is a '01 GTP with 120K. Thanks for any info.
  2. #2 Re: Very stiff brake pedal?
    If your brake booster isn't working you either have a vac leak somewhere or you need a new brake booster.
  3. #3 Re: Very stiff brake pedal?
    Donating Users busmech's Avatar
    Apr 2009
    Minneapolis MN
    It could be ice in the vacuum line or the check valve in the vacuum line they collect a lot of moisture in ther and can freeze...look in there...just a starting point...
    "Turbocharging is nice...but I'd rather be BLOWN!!!
  4. #4 Re: Very stiff brake pedal?
    Donating Users
    Chester County PA
    Matt5112, thanks for the input but if there was a leak in the vacuum line or the booster was leaking wouldn't it be a constant problem rather then intermittent?
    buemech, thanks for the info. I will definitly check the system for any ice build up. If that is the problem is there a way to keep it from happening in the future?
    PS I definitly agree with your opinion of turbo versus blown!!
  5. #5 Re: Very stiff brake pedal?
    Yeah you're right.
    I'm not overly familiar with brake boosters but i know they're not that bad to replace.
    Ones from junkyards can be had for cheap so other than hunting around, I'd replace it.
  1. Brake Pedal Positioning Sensor
    By DrDino in forum Introductions/Noob Questions
    Last Post: 01-21-2011, 12:38 AM
  2. shift selector lever very stiff
    By almighty in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-19-2009, 05:18 PM
  3. low brake pedal
    By johnk in forum Brakes/Suspension/Chassis
    Last Post: 11-15-2009, 07:58 PM
  4. Pedal Swap
    By Stpman in forum General Tech Discussion
    Last Post: 08-15-2009, 09:09 PM
  5. Trans linkage stiff???? Need help!!!
    By drums4life0922 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-03-2008, 11:25 AM
