Thread: Rumble when turning right.
Results 1 to 5 of 5
  1. #1 Rumble when turning right.
    Nov 2008
    Cedar Rapids, IA
    Hey guys, I've got a 99 GT and it has developed a slight rubbing or grinding noise when the steering wheel is turned slightly to the left. It is slowly becoming more noticeable but I can't find the culprit. The car does not make the noise when actually turing a corner, but when going down the interstate and the wheel is turned slightly to adjust within a lane. Checked the fluid and such and it's all good. Any ideas?
    2002 GTP Coupe *Bronzemist *FWI *180t *2.5 ZZP o/r pipe *Poly mounts *GMPP rear sway *GMPP trailing arms *Tune by FoSHO99
  2. #2 Re: Rumble when turning right.
    sounds like a wheel bearing
  3. #3 Re: Rumble when turning right.
    Nov 2008
    Cedar Rapids, IA
    Hmm, didn't think of that but it's entirely possible.
  4. #4 Re: Rumble when turning right.
    swift current,sask.
    Quote Originally Posted by 02GrandPrixIraqVet View Post
    Yup that sounds right, jack you car up and check for play in the bearings and tie rods. bearings will be up and down, tie rods will be left to right. There should be no play in either.
  5. #5 Re: Rumble when turning right.
    Charles City, IA
    Wheel bearing can be left and right too.
    SMGPFC Two Nipple General
  1. 97 gtp vibrate/rumble..
    By foogie in forum Brakes/Suspension/Chassis
    Last Post: 10-18-2009, 07:58 PM
  2. Key not turning back all the way.
    By DJO in forum General Tech Discussion
    Last Post: 04-14-2009, 09:03 PM
  3. Ignition not turning
    By alee90 in forum General Tech Discussion
    Last Post: 03-08-2009, 10:07 AM
  4. Turning a 01' SE into a GT
    By Dangerous313KidInAPrix in forum Visual/Body Modifications
    Last Post: 03-03-2009, 09:17 PM
  5. TCS not turning off
    By Keet04GTP in forum General Tech Discussion
    Last Post: 08-06-2008, 02:57 PM
