Thread: Got a squeak that won't go away...
Results 1 to 13 of 13
  1. #1 Got a squeak that won't go away...
    Jan 2009
    Tallahassee, FL
    Well I have an annoying squeak that is coming from the passenger side. At first it was only during so I put new pads on which did need replacing. It's still there and now appears just while driving, it's not constant either. The hub is also brand new, car drives fine otherwise. Could this just be the new pads, I know some can squeal real bad, the pads have been in since last friday.
    05 Saab 9-2X Linear (Saabaru)
    77 Morris Garage B
  2. #2 Re: Got a squeak that won't go away...
    SE Level Member PowerStroker's Avatar
    Minnesota, Eh?
    Where did you have the brakes done? There's 2 metal 'clips' that snap into the caliper bracket, and if they aren't cleaned/lubed, the pads will squeak whenever they move... A lot of small shops won't do this, or take the floater pins out of said bracket to clean and lube them. Therefore creating uneven brake pad/rotor wear...
    2003 F-350 7.3L Powerstroke, hybrid (burns diesel and rubber ), lots of mods, and gets 22.5 mpg!
    2000 Grand Prix SE 3.1L
  3. #3 Re: Got a squeak that won't go away...
    Jan 2009
    Tallahassee, FL
    I did the brakes, lubed the pins and installed new clips.
    77 Morris Garage B
  4. #4 Re: Got a squeak that won't go away...
    GTX Level Member a98gtp4u's Avatar
    GEORGIA
    get in there and start spraying everything with wd40. lol.
  5. #5 Re: Got a squeak that won't go away...
    Jan 2009
    Tallahassee, FL
    WD40+heat=fire. lol, I'm not taking that chance. Besides everything needs grease. I'll get in there and regrease everyhting and see if that helps.
    Also squeaks when I take a right turn, nothing turning left.
    77 Morris Garage B
  6. #6 Re: Got a squeak that won't go away...
    GEORGIA
    Lol, i was just messin wit u. Its just i saw some hispanic guys doin that 2 a lincoln that was squeaking, they spayed everywhere un der the car. I was crackin up.
  7. #7 Re: Got a squeak that won't go away...
    GEORGIA
    But honestly, it could be the ball joints. Had a mustang that squeaked when i hit a bump and turned right. Check them out.
  8. #8 Re: Got a squeak that won't go away...
    Jan 2009
    Tallahassee, FL
    Also noticed that it's squealing till I get up to around 30, it's much more faint than it was last week with another new hub. Hopefully this brake quiet stuff will work, this ****'s annoying. and embarrassing to me to.
    77 Morris Garage B
  9. #9 Re: Got a squeak that won't go away...
    Jan 2009
    Tallahassee, FL
    After putting on the antisqueal stuff car still does it.
    77 Morris Garage B
  10. #10 Re: Got a squeak that won't go away...
    Apr 2009
    methuen
    have you checked the back of the rotor to see if there is something rubbing. Check the bracket that holds your abs sensor, sometimes the bottom of the bracket can be bent in and could be rubbing the back side of your rotor.
  11. #11 Re: Got a squeak that won't go away...
    Jan 2009
    Tallahassee, FL
    Stupid me didn't even think about the rear pads, it was them. Just always sounded like it was from the front.
    77 Morris Garage B
  12. #12 Re: Got a squeak that won't go away...
    Joliet, IL
    Quote Originally Posted by Sandman View Post
    00 Silvermist GTP
    13.2 @ 104. No Cam No IC.
  13. #13 Re: Got a squeak that won't go away...
    Jan 2009
    Tallahassee, FL
    Quote Originally Posted by BoostJunki3 View Post
    Exactly, now I got a pesky pulley squeaking under the hood somewhere...
    77 Morris Garage B
  1. 4t65-hd trans squeak??
    By JAY0369 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-23-2011, 04:36 AM
  2. Squeak when going over Big/Speed Bumps
    By ravi in forum Brakes/Suspension/Chassis
    Last Post: 08-19-2009, 02:01 PM
  3. loud squeak drivers side on left turns only
    By jsveen in forum Brakes/Suspension/Chassis
    Last Post: 05-26-2009, 08:20 PM
  4. Perpetual belt squeak
    By Coogles in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-23-2008, 09:07 AM
  5. 3.4 pulley squeak
    By pacoflyer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-28-2008, 12:15 PM
