Thread: brake fluid
Results 1 to 5 of 5
  1. #1 brake fluid
    GT Level Member grand2000prixgtp's Avatar
    Grayslake
    is all brake fluid synthetic? is it ok to use in my car?
    2000 GTP silver four door, K&N cone filter, autolite 104 plugs, slp cat back, 3.4 pulley, zzp pcm, pacesetter headers, zzp stage 1 throttle body, ported superchrger, F body brakes. sold...
    2004 GTO all stock for now.
  2. #2 Re: brake fluid
    Houston, TX for now
    Brake fluid is made both conventional and synthetic. You should be able to run either as long as it is DOT 3 compatible. I personally use Valv. DOT 4 fully synth. in my 2000.
    2000 GRAND PRIX GTP COUPE WITH THE NORMAL LIST MODS TO MAKE IT LOUDER, FASTER AND OF COURSE SEXIER!! 267 WHP @ 9000 FT ABOVE SEA LEVEL
  3. #3 Re: brake fluid
    Donating Users mystic231's Avatar
    Michigan
    DOT 3 and DOT 4 are acceptable AND interchangable. DO NOT use DOT 5. Always use a fresh container, never any "leftovers". Brake fluid absorbs moisture and you want to keep that out of your brake system.
    '98 Bright Red GT 278,000 miles and counting...
    '02 Galaxy Silver GTP GMPP Suspension, F Body front brakes, TDC FWI intake, Ported M90, Intake, and Throttlebody, Overkill PCM
    '02 Bright Red GT
  4. #4 Re: brake fluid
    Grayslake
    so synthetic will be fine then?
  5. #5 Re: brake fluid
    TDCRacing
    Guest
    It sure will
  1. How much fluid do i need? Thanks
    By GTPJOE90 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-22-2009, 07:50 PM
  2. Fluid
    By BwolfGT in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-16-2009, 11:11 PM
  3. Trans. Fluid?
    By BwolfGT in forum General Tech Discussion
    Last Post: 04-11-2009, 05:26 PM
  4. Brake Fluid
    By 04gpking85 in forum Brakes/Suspension/Chassis
    Last Post: 01-19-2009, 09:27 PM
  5. How much fluid does the s/c take?
    By brodyman in forum General Tech Discussion
    Last Post: 09-17-2008, 02:15 PM
