Thread: Brake vibration
Results 1 to 3 of 3
  1. #1 Brake vibration
    Ontario
    I just installed new front rotors and pads last week after feeling heavy vibration while braking.
    The front pads were almost done but the back have lots of life. I am still getting vibration.
    Could anyone point out if I would be feeling it from the back end? I jacked the rear and turned the wheels with only a slight warp being seen. I replaced the front with cross drill rotors and they turn without any warp being felt when jacked up. They do have some drag while tuning by hand. Is that normal?
    I thought I could save some $'s but not seeing the results. Should the rears be changed even with a slight warp on both sides?
    Real Name: Dave
    Private messageWebsite
  2. #2 Re: Brake vibration
    Nov 2008
    Searcy,Arkansas
    A slight warp can cause the vibration. I would go ahead and change them and get them turned. Also make sure your not over torquing your lugnuts that can cause the vibration and it can warp your rotors.
  3. #3 Re: Brake vibration
    Ontario
    I have followed the proper procedure for tighning lugs. I use an impact with 100 lb torque stick, that way it stops at 100 lbs. I hate to throw parts out that have hardly any wear at 48000km the rears are shot? Something was not designed right at GM.
  1. Vibration
    By Klutch in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-26-2009, 02:52 PM
  2. Odd Vibration
    By VGPGT in forum General Tech Discussion
    Last Post: 04-15-2009, 04:18 PM
  3. vibration
    By david hagaman in forum General Tech Discussion
    Last Post: 04-11-2009, 11:16 AM
  4. Vibration
    By silvertip in forum General Tech Discussion
    Last Post: 04-09-2009, 09:09 AM
  5. vibration
    By vwthumper in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-07-2008, 05:24 AM
