Thread: Need a little help
Results 1 to 7 of 7
  1. #1 Need a little help
    GTX Level Member stlmo_gtp's Avatar
    St. Louis
    alright so i went to switch my rear trailing arms and sway bar. The sway bar went fine but now i am stuck on the trailing arms. i got all the bolts out except for 1 which is the one that goes to the hub I already took the nut off so my question is what it the trick to getting the bolt out?
  2. #2 Re: Need a little help
    SE Level Member rfmgtp02's Avatar
    Oct 2008
    Voorhees NJ
    bump... i am having the same problem right now. anybody know?
    2002 GTP 2DR Red Fire Metallic
  3. #3 Re: Need a little help
    GT Level Member djrepoman's Avatar
    columbus ohio (polaris)
    I had to use a 3/4inch impact to remove mine. steel bolt into aluminum FTL
    2000 GT ,E85 powered, and still slow
    98 GTP Stock
  4. #4 Re: Need a little help
    Charles City, IA
    Put the nut on a little bit and hit it with a hammer it will push the bolt out.
    SMGPFC Two Nipple General
  5. #5 Re: Need a little help
    GTX Level Member Ridin ON Chrome's Avatar
    Houston/Baton Rouge
    BFH and pb blaster
    98 GTP-Mods? Yeah, lots of them
    2009 HEMI RAM- Mods are in the works!!
    01 Regal GS-SOLD :-(
  6. #6 Re: Need a little help
    GTP Level Member BlownBigBlock's Avatar
    Apr 2009
    Carlisle PA
    Quote Originally Posted by Ridin ON Chrome View Post
    BFH and pb blaster
    Mine was so galled on I ended up taken the entire hub assembly off and putting it in a vise... Used plenty of PB, a 1/2" braker bar, an 4' bar entension and still ended up breaking parts off the hub assembly where the bolt went thru. Luckily had an extra set of rear hub assemblies..
    Major PITA job, used antiseize when putting back together.
  7. #7 Re: Need a little help
    i heated it with a torch then hit it with an 8 lb sledge hammer.
