Thread: ABS Issue
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
  1. #1 ABS Issue
    Michigan
    Okay . . . I've had it!
    I just bought my first Grand Prix. Its a 1997 Grand Prix GT Coup (3.8 non-supercharged). BEAUTIFUL car! I live in michigan, and its a kansas car, so it has little rust on the body. I've had some minor well-known issues with the car (such as a rear strutt going out/knocking, one of the cv joints just blew, and one of my window motors doesn't work well) all things I can fix. However, I have one issue that I can't figure out.
    My ABS / Traction Control / Tire Pressure lights come on, and it seems random. Normally you can tell if its a sensor by when the lights come on, but they just come on whenever they feel like it. For instance: I can start my car, on a cool day, and within 1 or 2 seconds the lights will come on, while Other times, I can start my car, drive around for an hour or two and the lights will never come on. Sometimes I can be driving and the lights will come on a half an hour down the road, other times I'll be driving and my ABS will just go nuts (I actually went through a red light once because my ABS was going off so much).
    I've had all 4 wheels off checking the links. All 4 connections seem solid, we unplugged them, checked for corrosion, and there was corrosion on only 1 of the connections, which we fixed, and plugged all back in making sure they were solid and connected to their clips. The front 2 wheel bearings look like they were recently replaced. The rear 2 look like they may be originals, but I don't hear any noise coming from them while driving. When we had the tires off, and we spun them, we didn't hear anything and they spun just fine.
    What else can I do to figure out whats wrong?
  2. #2 Re: ABS Issue
    PA
    Quote Originally Posted by m1sterb0b View Post
    When the ABS light comes on, it will set a diagnostic code that describes exactly what the problem is. So if you find out what that code is, you can troubleshoot the problem and fix it. This is very much like the service engine light and the diagnostic codes that it sets.
    Now the issue is that only a select few scanners can check these ABS codes. Most garages have them, but the common backyard mechanic typically does not. So your best bet is to ask a garage to retrieve the ABS coeds and tell you what is wrong. Most place will charge like $10-$20 for this. Then, if you want to fix it yourself, you can.
    2001 GSE
  3. #3 Re: ABS Issue
    Michigan
    Does the light have to be on when they test it, or can I bring it in any time? Because like I said, I never know when it comes on!
  4. #4 Re: ABS Issue
    PA
    Just make sure it has come on recently, like within the last week. It does keep a history, but it will clear out after so long. So make sure it was fairly recent that the light was on. But no, it doesn't need to be on when they scan it.
    2001 GSE
  5. #5 Re: ABS Issue
    Banned - Busted For Scamming
    Feb 2009
    are all your tires the same size and have equal tread left?
  6. #6 Re: ABS Issue
    Michigan
    They are all the same size tire, but 2 of them have a bit better tread than the others. While we had all 4 tires off sunday to check the ABS connections behind the wheels to the sensors, we actually rotated them because the front ones were looking quite bald. I do need new tires, but the ones on the front, that were on the back, are decent enough for now to get me by. I'm a college student so things like new tires get put on hold for a little bit because of how much they cost. I'm hoping to find a place that sells "gently used" tires for my car. My dad found them all the time for his Bonneville, but my grand prix has a wider tire, so I don't know how easy it would be to find for me.
  7. #7 Re: ABS Issue
    Feb 2009
    just asking b/c if you have a tire that has alot less tread than the other, it will set the light as that wheel will be traveling different speed than the other. It usually will set the light after driving for a couple of minutes and reset when you turn off the car.
  8. #8 Re: ABS Issue
    PA
    But this isn't typical. I have had tires with very different tread on my car before in various states, and never once did it set the ABS light.
    Typically, the ABS light in this situation is going to be caused by a bad WSS or bad wiring.
    2001 GSE
  9. #9 Re: ABS Issue
    Feb 2009
    it can happen and has happened. could be something else though, just throwing out the possibility.
  10. #10 Re: ABS Issue
    Michigan
    Yea, its possible. I figured you were leaning more towards them being slick tires not getting good enough traction, but that is a possibility. I doubt its true in my situation however, seeing as the lights can come on just 1 second after turning on my car.
    also, don't know if this helps any, but one time I was driving 55ish down a road, going completely straight (some small hills) and the lights came on. I threw it into neutral, turned off the car, turned it back on, put it back into drive and the lights didn't come on anymore the entire way home. The wires behind the wheels looked great, I don't see any wear on them, so I don't know if there would be an issue with the wires. This car is from Kansas, and has very little rust on it, and was a generally well-kept so I don't know about it being a wiring issue *unless its the wiring leading to the sensor behind one of the wheels from the wheels moving and vibrating.
    I just need to figure out which general direction the issue is in and get it fixed. I can't be sliding through any more red lights because the abs is going nuts lol.
  11. #11 Re: ABS Issue
    Feb 2009
    well that sucks, b/c the only real way you will know is to hook up an abs code scanner and wait for a code.
  12. #12 Re: ABS Issue
    Michigan
    alright. I'm glad to find out that at least there's a scanner for that. I've been told before that there wasn't, that the only code you can pick up would be if there is a "check engine light". thanks to everyone for the suggestions, I'll try to figure out what it is, and then come back and let you all know what it is!
  13. #13 Re: ABS Issue
    Feb 2009
    philly philly
    Sounds like a abs module having the same problem in my 04 Gtp scanned it and that is the code that came up
  14. #14 Re: ABS Issue
    abs module is not cheap!
  15. #15 Re: ABS Issue
    Michigan
    I took it in, got it scanned for 39 bucks. It shows that "random" codes were coming up. The mechanic said that the sensors looked really good, and since both traction control and abs were messing up that its most likely an ABS Control modual (the brain that controls the ABS). If its not that, then its going to be the abs module it self.
    Now, I know where the abs module is (its right next to the master cylinder) but where is the control module. How much will each of these parts cost?
  16. #16 Re: ABS Issue
    PA
    Whoa....you paid the guy $39 and he didn't even give you a description of the codes that it is throwing? Not to mention that anytime a wheel bearing or sensor goes bad, it will throw on the ABS and TC lights since the TC relies on the readings from the sensors to work properly. So a bad sensor or bearing will shut down the TC.
    But regardless, it will still have codes set that he should have gave to you, because that is what you paid him to do. Then you can do your own research and find out what is going on. But now, you paid him to give you his opinion. And I wouldn't put too much weight in just one opinion, yours, mine, or anyone's.
    2001 GSE
  17. #17 Re: ABS Issue
    Michigan
    I was standing there watching him do it. The only sensor code that it was shooting off was that the front left tire was grounding. We actually solved that issue before taking it in. He cleared the codes after looking at them, drove it around to see the new codes, and the ones that were coming up again were the ones he looked at. One of the codes said something about the ABS Module malfunctioning and that the most usual cause was the control module needing replacement. another issue said it was the abs module malfunctioning and that the usual cause was one of the motors in the abs module going bad. He didn't write down the code numbers, but he did write down what they said.
  18. #18 Re: ABS Issue
    GTP Level Member dstout's Avatar
    ky
    Don't know if this will help or not....my car is a 2003 and yours is a 97, when I had to replace my ABS module the controller/computer was bad.
    The unit itself is the pump and the controller and they are bolted together.
    The pump is aluminum with the brake lines attached and the controller is black with a wiring harness attached.
    You can see in the pic next to the intake, the label that says "for assembly only" with RB and a barcode below that......that black plastic houses the controller of the module the wiring harness is on the bottom .
    It is an expensive part that the dealer wanted more than $1,500.00 for the entire unit.
    I tell everybody that has had an ABS module issue here call Ed Morad he sells used GP parts and he might have a replacement for you....I paid $175.00 shipped to my door and that price was for the entire unit, pump and controller.
    I don't know what the module for a 97 looks like but it should look very similar I would think.
    Hope it helps you
  19. #19 Re: ABS Issue
    GTP Level Member Burbman's Avatar
    Dec 2008
    ****'s Creek
    My 98 GT has been lighting the ABS light on and off, last scan at the garage says the codes stored indicate the module is going bad. Can you change just the electronics or is it one unit with the pump? Anybody cahnge it out? Tough job?
  20. #20 Re: ABS Issue
    ky
    The electronics and the pump are two pieces that are bolted together and make a single unit, unbolt them and you have two parts.
    I think they are secured together with 6 torx security bits I don't remember for sure I would have to look later.
    The entire unit has to come out to replace the electronics/computer.
    It was a PITA but give yourself several hours and it shouldn't be a problem.
    I had several distractions...kids....x-wife...other than that it should be a couple of hours.
  1. RPM Issue
    By abuckley1290 in forum General Tech Discussion
    Last Post: 05-19-2009, 01:32 PM
  2. GTP pcm issue with ZZP
    By Regalgs98 in forum PCM Tuning
    Last Post: 02-18-2009, 02:16 AM
  3. I have a big issue please help me
    By Goany in forum General Tech Discussion
    Last Post: 12-02-2008, 02:51 PM
  4. Help with this issue please
    By TDCRacing in forum General Tech Discussion
    Last Post: 07-05-2008, 05:00 PM
  5. PM Issue
    By 04DetroitLS in forum Forum Bugs/Suggestions
    Last Post: 05-16-2008, 07:39 AM
