My 98 GT has been lighting the ABS light on and off, last scan at the garage says the codes stored indicate the module is going bad. Can you change just the electronics or is it one unit with the pump? Anybody cahnge it out? Tough job?
The electronics and the pump are two pieces that are bolted together and make a single unit, unbolt them and you have two parts.
I think they are secured together with 6 torx security bits I don't remember for sure I would have to look later.
The entire unit has to come out to replace the electronics/computer.
It was a PITA but give yourself several hours and it shouldn't be a problem.
I had several distractions...kids....x-wife...other than that it should be a couple of hours.
Thanks for the picture dstout, I'm pretty sure mine looks quite similar. My dad and I are going to pick up a replacement at a junk yard hopefully.
As for you being able to replace the control module apart from the actual abs module, yes, you can. The mechanic that checked it said there are several parts you can service yourself, the control module being one of them. He said that, if you really wanted to, you could replace the little motors inside of the abs module that control which brake gets how much power etc . . . I just need to get the parts and replace it. A junk yard will probably sell the control module with the abs module, most places don't find it worth-it to remove them from each other. Most people usually replace the whole unit anyways.
I'm glad the picture helped you out
If you do find a good module in the junk yard and you have to remove it yourself....just cut the brake lines above the fittings about an inch, don't unscrew the fittings from the module untill you are ready to install it. If you keep it upright it wont leak or you can crimp the ends of the stubs shut.
I'm guessing this will make it so that I don't have to worry about air bubbles in the abs and will make it easier to bleed the brakes once I'm done?
My dad and I really like to use GM's 3.8 and we've had 3 of them now that have abs. We've seen the same thing. Its just there was only 1 wheel sensor that was throwing a code and it was the LF. That one and the RF are pretty new, not to mention there was only one instance of that code in the memory and when my dad and I had that wheel off before getting it checked we saw that the connection wasn't hooked up to the bracket so it was swaying, when we disconnected the wires we saw a lot of corrosion, we cleaned it up and put some dielectric grease on it and it didn't throw another code. The mechanic took it down a dirt road (actually the dirt road he and I both live on) and drove it up and down it. The road has some nice sharp curves and he made some "ABS stops" making sure to stop on really loose gravel to make the abs go off. He got both lights to trip, but all of the wheel sensors showed they were fine, and none of them tripped, so he said he strongly thinks its not a wheel sensor, but I have seen that happen before.
