Thread: Installing front brakes
Page 2 of 2 FirstFirst 12
Results 21 to 34 of 34
  1. #21 Re: Installing front brakes
    Charles City, IA
    Impact FTW!
    SMGPFC Two Nipple General
  2. #22 Re: Installing front brakes
    GTP Level Member Scimmia's Avatar
    QCA, IA
    Impact FTW!
    You ain't gettin an impact in where he's talking.
    2001 Buick Regal LS - Almost Stock
  3. #23 Re: Installing front brakes
    GT Level Member GPSims39's Avatar
    Nov 2008
    Hauppauge, NY
    ok borrowed a breaker bar and ready to do this lol, should be ALLL done tonight,
  4. #24 Re: Installing front brakes
    TDCRacing
    Guest
    Cool
  5. #25 Re: Installing front brakes
    Nov 2008
    Hauppauge, NY
    i feel as if i will never finish this project, breaker bar is amazing, 123 bolts off....and hm....why the caliper wont slide off...wait...the instructions state pull foward from the back of the caliper and up..ok....umm....YEAH NOT COMMING OFF DAMN PEICE OF ^*&(*&(#)(!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! so after i chugged an ice cold miller lite to calm myself i sat and poked it for a few min and just put the bolts back on and the wheel....and gave her a bath...HOW THE @$(#$ do i get the damn caliper off now LOL
  6. #26 Re: Installing front brakes
    QCA, IA
    pull harder.
    really, the issue is just that the pressure of the piston is getting it hung up, pull from the back pretty hard and it should force the piston back in some, then it should come off.
  7. #27 Re: Installing front brakes
    Nov 2008
    Hauppauge, NY
    i didnt wanna pull to hard lol, i figured it was the pressure of the piston but the car rocked a bit each time and iw as like umm....yeah dont need this thing to come down (even tho i had it jacked with stands) ok so pull harder got it, haha tomorrows project AGAIN!
  8. #28 Re: Installing front brakes
    NH
    Quote Originally Posted by Scimmia View Post
    So, I have an '04, do you mean I can't get an impact in there for the front, rear, or both? The front ones are kind of stupid tight - 133 Ft-Lbs.
  9. #29 Re: Installing front brakes
    Banned - Busted For Scamming
    Feb 2009
    just use a breaker bar and be done with it
  10. #30 Re: Installing front brakes
    Nov 2008
    Hauppauge, NY
    yup, it became my best friend on this project
  11. #31 Re: Installing front brakes
    GT Level Member JJ91284's Avatar
    Schaumburg, IL
    my portable sears craftsman tool set thats always in my car, I leave a piece of conduit pipe in their that like 12 or so long. I just slide the conduit pipe over my 3/8 drive ratchet which in effect doubles the length of the ratchet which increase my torque capacity greatly. Otherwise I just use my 1/2 drive breaker bar when ever I'm in the garage.
    1997 Black GTP 72k (4dr), 3.5 Pulley, Wbody Downpipe, Wbody Shift kit (street), DHP 1.0, NGK TR55ix Spark Plugs, GMP Handling kit, KYB AGX Struts, AT Italia Inox 245x45x18 Goodyear Eagle F1, GMPP Springs, Corvette C5 Calipers, Blazertech 3200, DHP Powertuner (97-03), Built Trans, Torsen Diff
  12. #32 Re: Installing front brakes
    Jul 2008
    Tampa, FL
    can't you just use a clamp on the piston to hold it in while you slide the piece off? just tighten the clamp down to reduce the pressure?
  13. #33 Re: Installing front brakes
    NH
    I bought a 24" breaker bar thinking if 18" is good, a 24" one is better ... well I didn't have room to swing it with all of the slop in the socket and tools so I almost gave up.
    I had a flash of inspiration and put the front on ramps long enough to get underneath and use the breaker bar on both sides. Then I got the car off the ramps and jacked it up.
    I got both sides done yesterday with a little propane torch help to loosen the parts that were still sticking and making it a bear getting the bolts out. Now I just have to do the rear brake pads and rotors which should be interesting with the e-brake and all.
    Thanks for the help!
  14. #34 Re: Installing front brakes
    Nov 2008
    Hauppauge, NY
    little over kill with the torch lol my bolts were really stuck so with the breaker bar on the bolt/or nut, i just grabbed my handy dandy hammer and WHACK WHACK i hear the creak of the bolt/or nut and then it was smooth sailing
  1. Installing 6 1/2 Inch Front Speakers [*]
    By webracin in forum How To Write-Ups/Tech Tips
    Last Post: 04-28-2012, 11:45 PM
  2. F-Body front Brakes
    By TMC in forum Brakes/Suspension/Chassis
    Last Post: 01-19-2009, 11:49 PM
  3. need help installing nitrous
    By jordans gtp in forum General Tech Discussion
    Last Post: 01-05-2009, 11:04 PM
  4. installing LOC
    By Preston in forum Audio, Security & Visual Electronics
    Last Post: 09-12-2008, 12:08 PM
  5. Installing HUD?
    By retski420 in forum General Tech Discussion
    Last Post: 03-17-2008, 02:29 PM
