Thread: Wiring diagrams needed
Results 1 to 5 of 5
  1. #1 Wiring diagrams needed
    SE Level Member Ddk4's Avatar
    Oct 2016
    North Carolina
    Looking for wiring diagrams that show the ABS system and radio on an 01 GTP, recently under heavy acceleration my car started lighting up the ABS, Trac control, and Trac off lights all at once, plus the radio will either turn off or the volume is turned down, after the revs come down all the lights turn back off and the radio volume goes back up, looking for anything these systems have in common
    Sent from my XT1710-02 using Tapatalk
  2. #2 Re: Wiring diagrams needed
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    I've got plenty of diagrams I'll post later, but I know off hand that the speed sensor will affect the radio volume if it's off.
    What codes do you have? I'd start by fixing your abs code first
  3. #3 Re: Wiring diagrams needed
    Oct 2016
    North Carolina
    No abs codes, the light isn't on unless in that situation then it turns right back off with the Trac control and Trac off lights
  4. #4 Re: Wiring diagrams needed
    Aug 2017
    Raytown, MO
    Interesting. I'd be curious to see what the speed sensor data per wheel looks like normal and when this happens. With my scanner, I could just log a drive and capture the data.
    Intermittent problems will be very hard to track down without that. I'll post the diagrams when I can though.
    Easydiag 2.0 is what I use for diagnostics like this. I think I paid $70? It's well worth it
  5. #5 Re: Wiring diagrams needed
    Oct 2016
    North Carolina
    Thanks, that would be useful, I've had lots of intermittent electrical and fueling issues with this car
  1. Where can I get wiring diagrams for 04+?
    By April Thompson in forum General Tech Discussion
    Last Post: 03-23-2015, 06:19 AM
  2. HUD wiring diagrams
    By ms3206 in forum Audio, Security & Visual Electronics
    Last Post: 01-13-2013, 07:31 PM
  3. wiring diagrams
    By iluvbst in forum General Tech Discussion
    Last Post: 08-08-2010, 03:38 PM
  4. Wiring diagrams
    By Wadeb79 in forum 04+ Specifics
    Last Post: 08-27-2009, 07:46 PM
  5. 2004+ wiring diagrams
    By Toasty in forum General Tech Discussion
    Last Post: 01-14-2008, 01:15 PM
