Thread: Where can I get wiring diagrams for 04+?
Results 1 to 7 of 7
  1. #1 Where can I get wiring diagrams for 04+?
    GT Level Member April Thompson's Avatar
    Dec 2014
    Moline, IL
    I want to get my car wired with side repeaters, and I don't know where to tap into so I can have the indicators work without inadvertently tapping into either the DRLs or the brakes. Can someone please help?
    2004 Grand Prix GT2-clone A.K.A. the "Cybercar;" Galaxy Silver; 146K miles; RETROFITS: leather-wrapped steering wheel (w/audio controls) & shift knob; trip computer; map lights & dual lighted vanity visors; heated (?) leather seats w/ 10-way power driver's seat; ​HUD conversion
  2. #2 Re: Where can I get wiring diagrams for 04+?
    Aug 2012
    Stonington, CT
    Try the Auto Zone web site, they offer access to all sorts of technical info, including very good and very detailed wiring schematics, I have had good luck with them. You have to register on the web site to access them, but there is no expense involved.
  3. #3 Re: Where can I get wiring diagrams for 04+?
    Moderator DanPrixGTP's Avatar
    Jun 2011
    Grand Rapids, Michigan
    I have access to Snap-On's website, ShopKeyPro.
    What wiring diagram are you looking for? I might be able to pull it up for you.
  4. #4 Re: Where can I get wiring diagrams for 04+?
    Dec 2014
    Moline, IL
    I was looking for where to wire in side repeater turn signals, and I want to find out where to tap in to get just the turn signal and not either the DRLs from the front or brakes from the rear...
  5. #5 Re: Where can I get wiring diagrams for 04+?
    Aug 2012
    Stonington, CT
    You could pull the turn signal bulbs (front left and right) and tap the wires that feed the +12 volts to them, not sure which one of the two wires feeding each bulb is the hot side and which is ground, bit that would be easy to figure out with a voltmeter with the turn signal turned on.
    My main question is why do you need to add side repeater turn signals? Funny you mention them, on the same day you made your post, I saw a late model car that someone had added them to and wondered what the heck was up with that?
  6. #6 Re: Where can I get wiring diagrams for 04+?
    Dec 2014
    Moline, IL
    I'm planning on moving to Scotland, and I need the car MOT-compliant; side repeaters are part of the exterior lighting package. If I can knock a few pounds off of the price for converting it, then I'll do what I can!
  7. #7 Re: Where can I get wiring diagrams for 04+?
    Aug 2012
    Stonington, CT
    If you pick up the voltages going to the front turn signal lights, they will "repeat" exactly what the the turn signals do...if the turn signals are continuously on as running lights at night, or as DRLS, they side repeaters will stay on as well, but they will also flash as needed on turns. They will not come on with braking. I believe that on side repeaters I have seen, such as on European delivery Volvos and MBs that are then used here, the side repeaters will be on solid most of the time, and flash as needed on turns. Would that be a problem for the MOT compliance?
    If there is a concern with adding the additional current draw of the side repeaters to the front turn signal circuit, you could use the front turn signal bulb voltages to energize relays that would in turn switch voltage on an added dedicated fused supply circuit from the battery to the repeaters. You can get the relays at any auto parts store. The circuit positive could be connected right to the battery via a fuse in an in-line holder. No current will be drawn unless the turn signals are actually turned on, so you should not need to route the power through the ignition switch to prevent draining the battery with the car not running.
    I would think you would have more of a problem with driving a left hand drive vehicle over there, even if it that was MOT compliant. On the few occasions where i have driven a large American LHD car on roads in places where the British drive to the left rule is followed, it was kind of unnerving going around curves, hard to see the oncoming traffic when you are way over toward the shoulder of the road vs being closer to the middle of the road, especially on narrow roads that are common in the UK, and everyone drives like they are in a cross country rally.
  1. HUD wiring diagrams
    By ms3206 in forum Audio, Security & Visual Electronics
    Last Post: 01-13-2013, 07:31 PM
  2. 2004 CompG wiring diagrams
    By RivMan in forum General Tech Discussion
    Last Post: 12-05-2012, 11:19 AM
  3. wiring diagrams
    By iluvbst in forum General Tech Discussion
    Last Post: 08-08-2010, 03:38 PM
  4. Wiring diagrams
    By Wadeb79 in forum 04+ Specifics
    Last Post: 08-27-2009, 07:46 PM
  5. 2004+ wiring diagrams
    By Toasty in forum General Tech Discussion
    Last Post: 01-14-2008, 01:15 PM
