Thread: Front right axel
Results 1 to 17 of 17
  1. #1 Front right axel
    Sep 2012
    fort Wayne, in
    So got some work done to the car and noticed the axel is leaking alittle bit. I looked on rockauto and ac delco is roughly about 200 for I think the set and looked on zzp for stage 1 for 85 non he but reviews said they were trash. Suggestions? Also looking at doing the bushing on that same side.
  2. #2 Re: Front right axel
    Just go to napa and buy a new axle, they have a warranty and no need to worry about shipping anything.
  3. #3 Re: Front right axel
    Dec 2012
    troll land
    I'd just change the boot if axle is still good
  4. #4 Re: Front right axel
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Just so you know the right AC delco axle on rock auto is not available. I've tried to order it several times and it will not go through. It will come back as no longer available part. Napa is probably the best place to get an aftermarket axle. They are just cardone reboxed though. Do not use autozone axles, they suck and don't fit correctly
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  5. #5 Re: Front right axel
    May 2016
    Burns City, Indiana
    Depends, if you buy reman most are either CST or A1/Cardone. Bad thing is some are only getting rebuilt CVs but reason is so many come in with no joint issues and they get torn down ,inspected, cleaned, regreased and new boots. But honestly last time I bought a boot kit, it was nearly $30, a NEW axle like one that came in trunk of my new 04 GPGT2 is $79, lifetime guarantee most places. No brainier, link head abused old ones or brand new. Some reman grades specify all new joints. This is where due diligence is in order. Also investing in small trianglar file and doing some manicuring of the ends of splines can make even best new axles slide right in with minimal effort. Also don't forget a bottle of silver anti seize for alxe threads, splines and even lug nuts. Make things tighten properly. And axle nuts, snug in air, drop car till tire touches ground and torque to 100lb ft, I like to do this, set car down on wheel, use breaker bar to back off just 1/8 to 1/4 turn ,one at time and then reseat/torque lug nuts. The first time around with anti seize. Just gets it all smeared around. BUT don't slather, brush it into threads and splines. It also works well inside of spindle when replacing hubs. The greenish gold is copper based and only used on high heat bolts like exhaust or EGR.
  6. #6 Re: Front right axel
    I'll never put anti seize on lug studs, that is the last thing in the world I want coming loose. Good clean threads with a proper torque will never come loose.
    ****ing pain in the ass when you have to do rotates or brake work in a shop and some tard went all crazy with anti seize on the rotor hats and lug nuts. The stuff never comes off your hands, gets gloves all slimey and god forbid it gets on your pants or shirt and you enter the customers vehicle and get it on the interior.
  7. #7 Re: Front right axel
    Dec 2012
    troll land
    I'm currently dealing with a reman axle on my car. Lasted mebbe a year before slack. And when they "remanned" it they over machined the groove for the lock ring so now its refusing to come out. Meanwhile my 359000 mile passenger axle is just as tight as it ever was. Get a boot kit
  8. #8 Re: Front right axel
    GTP Level Member
    Jun 2016
    Cleveland ohio
    100% correct. Never put anti seize on lug nuts. When you get it on your pants of course the next car you pull in is a new Lexus.
  9. #9 Re: Front right axel
    GTP Level Member buck531's Avatar
    Aug 2011
    Gahanna, Ohio
    From what I've been told the NAPA reman axles use OEM parts to rebuild them. NEW Napa axles will work but they're not as good as the OEM rebuilt ones.
    FWIW I had new Napa axles on mine and just last year had to replace both of them. They were a good 50k miles old so that wasn't too bad.
    03 GS - SSAC, AEM wb, PT,SR rockers, Gen 3, 3.4, dynotech trans w/ 3.29's.
    87 Fiero GT. L67 Swap. XP, ported heads/sc. N* TB, FSIC, 2.8, 12.018 @ 113 1.71 60'.
  10. #10 Re: Front right axel
    Dec 2012
    troll land
    50k is not long at all for axles to last. Factory ones last 200k+
  11. #11 Re: Front right axel
    May 2016
    Burns City, Indiana
    First of all anti seize WILL NOT CAUSE A LUG NUT TO LOOSEN. The only thing that allows lug nuts too loosen is loose flakey corrosion or rust buildup under wheel not allowing it to sit properly and maintain proper fit or stretched or damaged studs. See it's not the wheel to hub face/rotor surface that keeps wheel tight it is bolt/stud stretch/tension. Just like cylinder heads retention is critical to proper stretch of the wheel stud and not having any debris under wheel.
    Now if your theory is true than head studs, connecting rodnuts/bolts etc should be torqued DRY and ARP didn't spend millions developing the moly lube for thier fasteners. Nickel based(silver) anti seize does NOT affect or change wheel stud torque AND promotes a smoother, more accurate torque. Don't believe me take certification tests for heavy trucks. Heck Dayton duals with inner and outer studs are pretty much on any semi and if you don't anti seize them you gotta have blind holder to get inner wheel lug and outer wheel nut apart.
    When installing new studs you should lubricated the threads I'd using nuts pull them in. But tapered puller washers allow less thread stress.
    I have been in auto repair for over 30 yrs and NEVER had wheels come loose from silver anti seize use. The only reason a nut or bolt comes loose is from vibration(ie use some sort of locking washers) or under torque or fastener failure. The last of those us brought on more by over stretch and the stud/nut yielding under load. Also proper torque is critical. Ever have to fight a lug nut on or off? Just think of how many cars have rusted lugs, and fail to get properly tensioned lug nut/studs.
  12. #12 Re: Front right axel
    May 2016
    Burns City, Indiana
    Double post
  13. #13 Re: Front right axel
    SE Level Member Silversurfer Gio's Avatar
    Huntington station new york
    Duralast gold cv axels are pretty good, have a set on my gtp for a couple years now with no problem (knocking on wood as Im sayin that)��.
    2001 GTP special edition 2dr-3"downpipe,plogs,4 inch cai,dynomax exhaust,3.5 pulley,msd 8mm wires,flipped db's, gmpp front and rear sways,gxp trailing arms,gmpp stb's,kyb struts,wbs lateral arms.
  14. #14 Re: Front right axel
    Dec 2012
    troll land
    Autozone is where I got the axle that only lasted a year....
  15. #15 Re: Front right axel
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I went through 2 Duralast Gold (should be Duralast coal) before I made them refund money so I could get an OE axle.
  16. #16 Re: Front right axel
    Sep 2012
    fort Wayne, in
    And that's what my buddy told me just to go to AutoZone and grab one and I was like ehhhh
  17. #17 Re: Front right axel
    Dec 2012
    troll land
    If your axle is still good I'd just change the boot
  1. Axel: NOMNOM, 4T65E FOR LUNCH
    By AxelRod in forum Members Rides
    Last Post: 11-02-2017, 11:18 AM
  2. cv axel..please help!
    By sammie in forum General Tech Discussion
    Last Post: 02-28-2015, 05:44 AM
  3. Front Axel 2007 Grand Prix V6
    By JabezAbreu in forum Introductions/Noob Questions
    Last Post: 02-16-2013, 07:50 AM
  4. Bad axel? help please
    By triebenbach07 in forum General Tech Discussion
    Last Post: 11-17-2011, 11:53 PM
  5. Front axel bearing and hub assembly replacement
    By BSMet94 in forum Brakes/Suspension/Chassis
    Last Post: 08-15-2011, 11:34 AM
