Thread: Bad axel? help please
Results 1 to 9 of 9
  1. #1 Bad axel? help please
    Donating Users triebenbach07's Avatar
    Dec 2010
    long prairie, mn
    I've had my car lowered for 2 years and got sick of swapping wheel bearings everytime i do an oil change, so i put in the shorter dog bones that are supposed to correct the drivetrain geometry on lowered gp's.
    about that same time, a vibration started coming from the front drivers side suspension. it only happens while accelerating and turning or curving to the left, much more noticable when at higher speeds. (above 65mph)
    again, this only happens while accelerating, if i coast around a leftward curve, it doesnt exit. this has been the norm for the last month or so.
    I will rotate my tires tonight to see if that effects anything.
    Any thoughts would be very much appreciated. thanks in advance
  2. #2 Re: Bad axel? help please
    GT Level Member shart's Avatar
    Oct 2011
    Reading PA
    Id start by putting the regular dog bones back on and see if the issues goes away since it started happening right around the same time you made that change.
  3. #3 Re: Bad axel? help please
    PA
    Quote Originally Posted by shart View Post
    This. I had bad vibrations when I ran shorter dog bones.
    2001 GSE
  4. #4 Re: Bad axel? help please
    Dec 2010
    long prairie, mn
    Quote Originally Posted by Zef_66 View Post
    so if this is the culprit, is there an alternative fix so that im not constantly replacing bearings?
    and thanks for all of the help
  5. #5 Re: Bad axel? help please
    PA
    Quote Originally Posted by triebenbach07 View Post
    Good quality bearings. Lowering the car has little to do on the life of the wheel bearings.
    2001 GSE
  6. #6 Re: Bad axel? help please
    Dec 2010
    long prairie, mn
    the axel was, in fact the issue. thanks guys!
  7. #7 Re: Bad axel? help please
    Oct 2011
    Reading PA
    And FYI... If you jack up your car and take a look at your axel you will be able to get an idea if it needs to be replaced. Make sure its inserted completely into the transmission. You can do this by grabbing it and wiggling it back and forth.. you will have a very little bit of play but you will feel that it is in securely. If you see alot of nasty 'goop' resting right under the boot area, thats a good sign it may be time to replace it.
  8. #8 Re: Bad axel? help please
    Out West
    Axel foley?
  9. #9 Re: Bad axel? help please
    Dec 2010
    long prairie, mn
    i didnt have time to inspect the axels, but i did rotate my tires and put the stock dogbones back in and the problem still presists
  1. Front axel bearing and hub assembly replacement
    By BSMet94 in forum Brakes/Suspension/Chassis
    Last Post: 08-15-2011, 11:34 AM
  2. Leaking Trans Fluid (by axel)
    By TDgrand in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-06-2010, 03:20 PM
  3. axel nuts keep coming loose?
    By _nick_ in forum General Tech Discussion
    Last Post: 07-30-2008, 10:36 PM
