Thread: Hard Acceleration - Brake Fluid Warning Light
Results 1 to 9 of 9
  1. #1 Hard Acceleration - Brake Fluid Warning Light
    GTP Level Member
    Aug 2012
    st louis park, MN
    Occasionally, upon hard acceleration I have gotten a brake fluid warning light. This makes sense as the fluid might drop away from the sensor depending on where it is placed.
    However, it has gotten more frequent lately and now it just comes on when I start the car up. I check the fluid and the reservoir is about half full. I thought about topping it off but didn't want to open a large bottle of fluid only to top off the reservoir since it expires. I'd like to flush the system while I'm at it.
    Just curious if anyone has thoughts on what may be occurring. Maybe I should be looking for a leak in the system somewhere as the fluid could be dropping slowly and now it is to the point where it is tripping the sensor?
    Thanks,
    Joe
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  2. #2 Re: Hard Acceleration - Brake Fluid Warning Light
    St. Louis
    I'd be looking for leaks. Check the rear lines where they go through the subframe. I just blew out both lines recently due to rust there. Your level shouldn't drop in the master unless there is a leak somewhere. If you can't find a leak, then top it off and keep an eye on the level. If it goes down again then you know it's getting out somewhere.
  3. #3 Re: Hard Acceleration - Brake Fluid Warning Light
    GTP Level Member
    Aug 2012
    st louis park, MN
    Ok thanks.
  4. #4 Re: Hard Acceleration - Brake Fluid Warning Light
    SWPA
    I bet one of your rear calipers is leaking near the ebrake mechanism.
  5. #5 Re: Hard Acceleration - Brake Fluid Warning Light
    fill your master cylinder res, its low and making the light come on when the fluid moves away from the sensor. you either need new brakes really bad, or you have a leak for the level to get that low.
  6. #6 Re: Hard Acceleration - Brake Fluid Warning Light
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    As your brake pads wear, they get smaller. Thus more fluid remains in the caliper, and the level in master drops SLIGHTLY over years, probably. Brake fluid sensor is under the reservoir. Simple small plastic part, goes for about $5, takes less than 5 minutes to swap out.
    BTW: they do go bad, just changed mine this year. You don't need to bleed or flush just to change the part, only if you feel the need.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  7. #7 Re: Hard Acceleration - Brake Fluid Warning Light
    GTP Level Member
    Aug 2012
    st louis park, MN
    Ok thanks for the ideas guys!
  8. #8 Re: Hard Acceleration - Brake Fluid Warning Light
    SE Level Member jaydubb71's Avatar
    Apr 2013
    Waldorf MD
    ^^^Definitely what Cheatah Faheatah said...
    As your brake pads wear, they get thinner. As they get thinner, the caliper sticks out more. This displaces the fluid in the reservior.
    Check your brake pads first. If they are worn, replace them. The light should go out then...
    1998 GTP Coupe: Self-tuned with HPTuners, 3.4, FWI w/ 12 inch K&N, Autolite 103's, hot-wired FP, Caspers fan override, 180 t-stat, Speed Daddy headers, SLP exhaust w/ GTX tips, 12 inch brakes (Riviera/Impala), 6000K HID's, solid rubber engine and trans mounts, poly dogbone inserts (SOLD 3/2020!!! )
  9. #9 Re: Hard Acceleration - Brake Fluid Warning Light
    GTP Level Member
    Aug 2012
    st louis park, MN
    I'm aware of the pad wear vs fluid level relationship. I believe the fronts are good but I'll check them all anyway. I'll probably investigate in this order:
    Check for leaks
    Check pads
    Top off fluid
    Replace sensor (unlikely)
  1. Brake Warning Light
    By indygrandprix in forum Brakes/Suspension/Chassis
    Last Post: 02-28-2016, 04:21 PM
  2. Replies: 2
    Last Post: 07-20-2013, 08:25 AM
  3. 2006 GXP issue with Low Brake Fluid Sensor light
    By ascotell in forum General Tech Discussion
    Last Post: 06-25-2012, 08:35 AM
  4. Brake Warning Light
    By tgarison in forum Brakes/Suspension/Chassis
    Last Post: 09-07-2011, 06:53 PM
  5. Parking brake warning light on after fluid change
    By aziff in forum General Tech Discussion
    Last Post: 05-02-2011, 10:06 AM
