Thread: Cheapest place to get front-end suspension parts?
Results 1 to 20 of 22
  1. #1 Cheapest place to get front-end suspension parts?
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    So, we got the swaybar in the Regal; my brother drove it to his place and it wouldn't stop clunking in the front. So, he took it to a shop and found out the lower ball joints, left side control arm bushings, right control arm, and tie-rod ends are all shot. Probably from being driven with a broken front swaybar for a long while.... (life has given me so many lessons about used cars the last five months...)
    Anyhow, we're looking at around $700 worth of parts and labor from one shop ($250 parts, app. $350 for labor, and $100 alignment). Wondering if this is reasonable enough, or what the cheapest place to get these parts from would be, then have a shop install the ones that require special tools.
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  2. #2 Re: Cheapest place to get front-end suspension parts?
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    None of those are hard to do even if you have to do it in the cold there not that bad. I just suggest rock auto get greaseable everything I do and they seem to last me longer (I beat my car like a $2 whore) change it all your self then go get alignment and yea there prices sounds about right but why pay
    them to do something you could do with a basic set of tools And a little time
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  3. #3 Re: Cheapest place to get front-end suspension parts?
    Nothing requires anything special.
    A broken sway bar or a missing sway bar has nothing to do with the repairs that they say are needed.
    Tie rod ends are very common and same with control arm bushings. New control arms are 40 each for dorman parts and new tie rod ends are 10-15 per side or so. New control arms come with all bushing and new ball joints.
    Spend $120 in parts, 2 hours of your time and then get an alignment.
  4. #4 Re: Cheapest place to get front-end suspension parts?
    Jun 2015
    Don't you need a press tool to do the bearings?
  5. #5 Re: Cheapest place to get front-end suspension parts?
    You never said anything about a wheel bearing.
    And no, there aren no press in bearings. They all have their own hub already, only 3 bolts and 1 axle nut hold it to the knuckle.
  6. #6 Re: Cheapest place to get front-end suspension parts?
    Jun 2015
  7. #7 Re: Cheapest place to get front-end suspension parts?
    Jun 2015
    Oh. My brother said you needed special tools to do the ball joints, and control arm bushings.
  8. #8 Re: Cheapest place to get front-end suspension parts?
    Nov 2011
    NY
    Get the entire control arm with new bushings... Easiest way. Bushings would cost 60-70% of the cost of an entire new control arm. To pop the ball joint lose you may need a separator tool, or you can just be inventive, lol.
  9. #9 Re: Cheapest place to get front-end suspension parts?
    Jun 2015
    Well, I was really looking forward to spending $130 on parts..., but apparently my brother already took it to the shop to do. Nice.
    Thanks for the help guys, I'll def keep this info handy for the future!
    Now off to find some LeSabre parts....
  10. #10 Re: Cheapest place to get front-end suspension parts?
    If a T55 bit and some sockets are special tools, then yeah.
    It's cheaper/easier/faster to replace the entire arm than it is to try and replace the ball joint and bushing itself. The regular bushings are like 15-20 each and the new style are 35-40 each for just a bushing. Where as a new control arm is 40 bucks, and it'll last a long time.
  11. #11 Re: Cheapest place to get front-end suspension parts?
    Yes.
    And rockauto is cheaper. They are 39 each and MOOG brand is 44 each.
  12. #12 Re: Cheapest place to get front-end suspension parts?
    Feb 2013
    37.295091, -121.930053
    buying cheap parts dont equal quality parts. yeah sure cheap gets you by but you will be doing that same job sooner than if you bought good quality parts.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  13. #13 Re: Cheapest place to get front-end suspension parts?
    Dorman is factory quality, I see no issue getting similar mileage from them.
    Bill had close to 60-70k miles on a set with no problems.
  14. #14 Re: Cheapest place to get front-end suspension parts?
    Feb 2013
    i was talking over all lol
  15. #15 Re: Cheapest place to get front-end suspension parts?
    Donating Users moddman's Avatar
    Midwest
    If you want cheap and decent quality. Try Mevotech brand. They come with ball joints attached with bolts, not those damn rivets like OEM and Dorman.
    3.4" ZZP MPS Pull
    ey,ZZP Coupler,NGK PLUGS,L67 Coils,INTENSE 1.8 RR, Custom PCM Tune, ZZP Stage 2 IC, 180* T-Stat, 42LB RE-FLWD Inj.
  16. #16 Re: Cheapest place to get front-end suspension parts?
    Jun 2015
    Okay, thanks for the info!
  17. #17 Re: Cheapest place to get front-end suspension parts?
    SE Level Member USonuMabeaCh's Avatar
    Sep 2015
    gulf breeze, fl
    $100 alignment? You're getting taken to the cleaners, I thought some of the guys locally trying to charge $60 was highway robbery, but sheeeesh.
    I wouldn't pay a dime over $50 for an alignment.
    02 40th GTP 2dr SSEI IC ZZP system with 3.2" Wizaird CAI Transgo SK SD headers aeroforce w/WB 1.9s over kill tune | 70 Skylark 455 bored to 462 Stg 1 iron heads ported 270 in 205 ex spx intake 870 street avenger 2" headers 3" xpipe flowmaster 40's full msd ign custom cam 540 hp 560 lbft TH400 2800 stall hotchkis susp DTS 12 bolt 3.42 rear
  18. #18 Re: Cheapest place to get front-end suspension parts?
    Quote Originally Posted by USonuMabeaCh View Post
    Who does $50 alignments around here lol
    Usually around $70 gets you one here. If it's a dealership expect around $100 or so
    04 Comp G.
  19. #19 Re: Cheapest place to get front-end suspension parts?
    Jan 2013
    leavenworth ks
    $125 with two year warranty my home town but $89 where I live now and won't do any type warranty to many damn dirty roads
    Sent from my SM-S820L using Tapatalk
  20. #20 Re: Cheapest place to get front-end suspension parts?
    Yeah $100 for an alignment is way too much, even the most expensive place here only charges $80 for an alignment.
  1. Cheapest place to get AC compressor
    By camopaint0707 in forum General Grand Prix Discussion
    Last Post: 05-15-2013, 08:58 PM
  2. Looking for cheapest place to get struts
    By joshua_arndt in forum Brakes/Suspension/Chassis
    Last Post: 11-19-2009, 09:38 PM
  3. Cheapest Place to Find Spoiler
    By scottmmckinney in forum Visual/Body Modifications
    Last Post: 04-19-2009, 10:16 PM
  4. Cheapest place to get sd hood
    By robahr24 in forum Visual/Body Modifications
    Last Post: 02-26-2009, 09:00 PM
  5. Cheapest place to get AGX struts and vogtland springs
    By robahr24 in forum General Tech Discussion
    Last Post: 08-20-2008, 02:50 PM
