Thread: Worth swapping spring?
Results 1 to 5 of 5
  1. #1 Worth swapping spring?
    Jun 2015
    El Paso
    On my 00 gtp I want to change all the struts, but not sure if I should do strut assemblies to get new springs, or just swap the struts with the upper mount.
  2. #2 Re: Worth swapping spring?
    Feb 2013
    37.295091, -121.930053
    It's much easier to swap the whole thing if you have the spring compressors. Either way it's going to need the spring compressors to hold the springs
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  3. #3 Re: Worth swapping spring?
    Nov 2011
    NY
    All depends what you're looking for. If you have the typical rear sag, you may want to change springs too. Quick struts make for easy work, a bunch of bolts and its done, no need for spring compressors. If you have a set of aftermarket springs, well that's a different story then as you'd probably want to keep them.
    KYB GR2 Quick Struts is minimum is what I have and what I'd do. Good luck!
    KYB Part #'s (I Think) Front SR4002, Rears SR4003, SR4004
  4. #4 Re: Worth swapping spring?
    Jun 2015
    El Paso
    Quote Originally Posted by coolone View Post
    I assume it's the stock springs. I just got the car a few months ago and the struts do need to be replaced. I want to make it a track and daily driver, so further down the line I will add upgrades or should I just save and do them all at once?
  5. #5 Re: Worth swapping spring?
    Sep 2013
    Northwest Indiana
    In my experience, changing the rear springs is usually a good idea. Unless the fronts are sagging, or you plan to lower it, stay with the stock springs because new replacement ones tend to raise it about 1in over stock, giving it a bit of a monster truck look. I have w-body store springs on my gp, and while it sits perfect, the ride is WAY to stiff. My kyb agx struts have just enough power to make it tolerable.
  1. swapping
    By coreysGTP in forum Introductions/Noob Questions
    Last Post: 12-28-2012, 10:35 PM
  2. Is it worth it to put more money into the car than what its worth?
    By xander37 in forum General Tech Discussion
    Last Post: 01-17-2012, 06:28 AM
  3. Regal GS Spring Rate vs 40th Anniversary Spring Rate
    By 40th in forum Brakes/Suspension/Chassis
    Last Post: 04-09-2011, 10:57 AM
  4. Swapping PCM's
    By Clar2478 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-08-2009, 09:34 PM
