Thread: Brake Lights
Results 1 to 6 of 6
  1. #1 Brake Lights
    May 2012
    Jacksonville, Fl
    2002 Grand Prix GT, Corner brake lights do not work. Center/rear window brake light does works. Swapped bulbs with turn signal blubs and they work as do my turn signals. Tail lights burn. Can anyone tell me what is broke and what I need to replace? Thanks in advance for your assistance. Hope all are having an enjoyable Labor Day.
  2. #2 Re: Brake Lights
    So you have rear brake lights and the rear 3rd brake light in the center working but the little mini bulbs in the corners of the rear taillights do not come on??
    Because those are just running lights if I recall correctly, turn the headlight switch on and see if they light up.
  3. #3 Re: Brake Lights
    May 2012
    Jacksonville, Fl
    No, Perhaps I was not clear. The center/rear window brake light works. The other two brake lights located in the tail lights do not work. The turn signals work and the mini bulb corner lights work.
  4. #4 Re: Brake Lights
    Do you have a DMM to test for power and ground to the sockets?
    I'd even follow the harness back some to see if the wires go damage or if a connector is burned up. Double check fuses.
  5. #5 Re: Brake Lights
    Jul 2010
    Coquitlam,BC,Canada
    Check for power and ground at the socket. Sounds like maybe two bad bulbs.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  6. #6 Re: Brake Lights
    Nov 2015
    Rockford
    Try hitting the brakes while holding the turn signal lever back (like you're flashing your brights). If they work then then the turn signal switch in the column is bad
  1. No brake lights, signal lights or dash lights?
    By Red97GT in forum General Tech Discussion
    Last Post: 10-15-2014, 04:12 PM
  2. Help REAR TAIL LIGHTS NOT WORKING, BUT BRAKE LIGHTS WORK.
    By shihiran in forum General Tech Discussion
    Last Post: 10-21-2012, 02:35 PM
  3. no brake lights...sometimes
    By goldgp in forum Audio, Security & Visual Electronics
    Last Post: 08-06-2011, 03:59 PM
  4. ABS, Brake, P, and ! lights all on
    By nofronts in forum Brakes/Suspension/Chassis
    Last Post: 10-30-2010, 12:14 AM
  5. Brake Lights
    By gpgt in forum Audio, Security & Visual Electronics
    Last Post: 05-09-2010, 09:10 PM
